The sketch shown below is based on that of Tom Igoe (in turn acknowledging Heather Dewey-Hagborg) in this SPI tutorial.
The AD5206 in that tutorial is a 6-channel digital pot; I used a 2-channel one from Microchip, the MCP42XXX. The xxx indicates the maximum resistance in kilo-ohms, of 010, 050 or 100.
Although both products are SPI compliant digital pots, they differ subtly in the way they implement their commands, hence this how-to which shows how to handle the MCP version. The AD product receives two bytes: the first is the channel number in the 6-channel pot and the second is the 0-255 value to which that pot must be set. Two consecutive SPI.transfer commands in the sketch send those two bytes, and it seems the AD5206 is predisposed to receiving two bytes as a channel and data.
The MCP product, however, implements a Command Byte: the first byte sent is not merely the channel number, but also tells the chip what to do. See the datasheet for full details but for our purposes a Command Byte XX01XXpp is what we need to know:
XX = don't care
01 = the next byte is data (which seems to be pre-ordained in the AD product)
XX = don't care
pp = potentiometer to be accessed:
00 = use neither, dummy command
01 = use pot 0
10 = use pot 1
11 = use both pots
So taking the simple view that the X's will be 0, and discarding the dummy case, the Command Byte we would send would be:
00010001 = decimal 17 for pot0
00010010 = decimal 18 for pot1
00010011 = decimal 19 for both pots.
So the first SPI.transfer in the sketch below would send a 17, 18 or 19 rather than simply the raw channel; the second SPI-transfer sends the value.
The MCP product is physically different from the AD one, so here are the pin connections:
1 => Arduino 10 SS
2 => Arduino 13 SCK
3 => Arduino 11 MOSI
4 => ground
5 => ground
6 => LED with series resistor
7 => 5V
8 => 5V
9 => LED with series resistor
10 => ground
11 => not used here
12 => not used here
13 => not used here
14 => 5V
Here's a sketch, the behaviour of which is to cycle one LED's brightness, then the other, then both.
E&OE, YMMV
Digital Pot Control
Based on the original sketch for AD5206....
This example controls a Microchip digital potentiometer.
The MCP42 has 2 potentiometer channels. Each channel's pins are labeled
PAx - connect this to voltage
PWx - this is the pot's wiper, which changes when you set it
PBx - connect this to ground.
The MCP42 is SPI-compatible,and to command it, you send two bytes:
The first byte is the Command Byte which has this format when
the next byte is to be data: XX01XXpp
note these bits ...............^^.... the 01 means the next byte is data
(where pp = potentiometer selection, X= don't care)
pp= 00 = dummy code, no pot selected
pp= 01 = pot0
pp= 10 = pot1
pp= 11 = both pots
Simplest case is to have X= 0 so the Command Byte will be:
pp= 00: 00010000 = 16
pp= 01: 00010001 = 17
pp= 10: 00010010 = 18
pp= 11: 00010011 = 19
The second byte is the resistance value for the channel (0 - 255).
The circuit:
* All PA pins of MCP42 connected to +5V
* All PB pins of MCP42 connected to ground
* An LED and a 220-ohm resisor in series connected from each PW pin to ground
* CS - to digital pin 10 (SS pin)
* SI - to digital pin 11 (MOSI pin)
* SCK - to digital pin 13 (SCK pin)
created 10 Aug 2010
by Tom Igoe
Thanks to Heather Dewey-Hagborg for the original tutorial, 2005
Version for MCP42xx April 2013, Jim Brown
// include the SPI library:
#include <SPI.h>
// set pin 10 as the slave select for the digital pot:
const int slaveSelectPin = 10;
// set the slaveSelectPin as an output:
pinMode (slaveSelectPin, OUTPUT);
// initialize SPI:
SPI.begin();
// go through pp=01, 10, 11 for pot0, pot1 and both together of the digital pot:
for (int CommandByte = 17; CommandByte < 20; CommandByte++) { // 17, 18 and 19
// change the resistance on this pot from min to max:
for (int level = 0; level < 255; level++) {
digitalPotWrite(CommandByte, level);
delay(10);
// wait at the top:
delay(100);
// change the resistance on this channel from max to min:
digitalPotWrite(CommandByte, 255 - level);
delay(10);
int digitalPotWrite(int CommandByte, int value) {
// take the SS pin low to select the chip:
digitalWrite(slaveSelectPin,LOW);
// send in the address and value via SPI:
SPI.transfer(CommandByte);
SPI.transfer(value);
// take the SS pin high to de-select the chip:
digitalWrite(slaveSelectPin,HIGH);
