Split Flap Display Reverse Engineering and control with Arduino
Hello Friends,
I am working on reverse engineer a PCB motor controller of a Split flap display , the split flap works with a synchronous 48 AC motor.
this is what found in this PCB :
FQP50N06 Transistor MOSFET
MOC3020 : 6 Pin DIP Ramdom-Phase Optoisolators Triac Driver Output
4 x MC3302 : Quad voltage comparator
1 x MC1413B : Hight Volatge, Hight Current Darling Transistor Arrays
3x MC14516B : Binary Up/Down Counter
MC14081b : Dual 4-Input AND Gate
2 Photointerrupters ( I have 2 photo interrupters in this circuit, one for the tuning and one for the steps of the synchronous motor )
After 3 days of work i made an initial Control Schematic :
I want to use the original 16-conductor multi-drop ribbon cable ( check the top of PCB please), i want to know what i get from every conductor of the 16 conductors and control the motor using an arduino.
like the example here :
What should i do next ?
Many thanks for your help !
This thread is associated with many others, like this.
http://forum.arduino.cc/index.php?topic=414510.0
and
http://forum.arduino.cc/index.php?topic=415505.0
I would also be drawing in resistors and caps, this would help discern the two opto elements.
Now you need to convert that to a schematic.
Tom... :slight_smile:
TomGeorge:
Controling a Split flap Display System of 65 modules with Arduino via I2C bus - Project Guidance - Arduino Forum
and
Photo interrupter - General Electronics - Arduino Forum
I am sorry for the delay , I am saw the feedback i am going to delete this post and repost it again on the 2 topics
