SSD1963 + ESP32 (16-bit Parallel)
I recently purchased the screen that I sent you the link for. I thought it was 8-bit communication, but upon checking again, it is 16-bit. Now, I don't know if there is any way to make it 8-bit, or what other way I can use to communicate, because the ESP32 doesn't have enough pins, with the 17 pins it already uses if it is 8-bit. If it were possible for me to change the screen, I would, but due to time constraints, I can no longer do so. I'm asking because I really need the touchscreen and I don't know what solution is possible for me.
PD: The ESP32 uses other sensors, which take up another 2 GPI pins, and I also use SDA and SCL.
https://es.aliexpress.com/item/32916913295.html
In this video, it looks like you have exactly the same model as mine, but yours works, and mine doesn't give me any signal. It turns on, but it doesn't show any image or picture.
I moved your topic to an appropriate forum category @reyes_salomon0.
In the future, when creating a topic please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
I think the short answer is no.
Also would not recommend an an 8-bit interface display with ESP32, it would probably be slower than an SPI interface.
