Starter kit project 11 LCD problem
when I tested starter kit project 11, the whole Arduino uno rev r3 board was not working.
So I guessed that this problem was wiring problem. But the thing is that there was no problem with the wiring. But when I suddenly shook the Arduino Board the whole circuit and the screen turned on. So I hope that you could give me some answers!
Is project 11 the "crystal ball" project? Can you post a link to the online version?
I'm not familiar with the starter kit but found e.g. Trouble with Arduino Starter Kit: Project 11 Crystal Ball; did you solder the LCD?
Welcome to the forum
To me that indicates that there was a problem with the wiring. It may be that the circuit was wired correctly but that one or more connections were loose
Thank you!
Thank you to all of you who gave me a solution.
The LCD came soldered from the Arduino company.
And I just surfed the internet and found that there are none.
And I found a pdf file!
arduino-projects-book.pdf (7.2 MB)
Thank you for your suggestion!
