Stepper motor control with 1 button
Hi, i am new to Arduino.
Im looking for a scetch for a stepper motor. I want it to run a stepper for a certain amount of steps when a input button is LOW. Then when a input button is HIGH reverse the stepper dirction for a certain amount of steps. Using Visuino i have managed to get one direction and stop but can not get it to reverse just using one button.
Stepper is a 4 wire.
Any help would be greatful.
Thank you
That's unknown here. What is it?
Start by using some simple example code and modify it to suit Your needs. Have a look into the example folder in the IDE.
This i what Visuino has created for me, which i watched a video on utube. If i press the button i with step in one direction. But what im after, when i release the button the stepper will reverse for a certiain amount of steps.
#define VISUINO_ARDUINO_AVR4809
#define VISUINO_ARDUINO_NANO_EVERY
#include <OpenWire.h>
#include <Mitov.h>
#include <Mitov_LogicGates.h>
#include <Mitov_Counter.h>
#include <Mitov_BinaryGenerators.h>
#include <Mitov_Stepper.h>
// Shared Component Member Variables
namespace ComponentVariables
class
public:
bool Value1 : 1;
uint32_t Value2 : 31;
bool Value3 : 1;
uint32_t Value4 : 4;
bool Value5 : 1;
bool Value6 : 1;
} BitFields;
class Variable1
public:
inline static bool GetValue() { return BitFields.Value1; }
inline static void SetValue( bool AValue ) { BitFields.Value1 = AValue; }
class Variable2
public:
inline static uint32_t GetValue() { return BitFields.Value2; }
inline static void SetValue( uint32_t AValue ) { BitFields.Value2 = AValue; }
class Variable3
public:
inline static bool GetValue() { return BitFields.Value3; }
inline static void SetValue( bool AValue ) { BitFields.Value3 = AValue; }
class Variable4
public:
inline static uint32_t GetValue() { return BitFields.Value4; }
inline static void SetValue( uint32_t AValue ) { BitFields.Value4 = AValue; }
class Variable5
public:
inline static bool GetValue() { return BitFields.Value5; }
inline static void SetValue( bool AValue ) { BitFields.Value5 = AValue; }
class Variable6
public:
inline static bool GetValue() { return BitFields.Value6; }
inline static void SetValue( bool AValue ) { BitFields.Value6 = AValue; }
} // ComponentVariables
// Arduino Constant Declarations
namespace VisuinoConstants
class FloatValue0
public:
inline static constexpr float GetValue() { return 100; }
class FloatValue1
public:
inline static constexpr float GetValue() { return 0; }
} // VisuinoConstants
// Pin Call Declarations
namespace PinCalls
class PinCallerReceive0
public:
void Notify( void *_Data );
class PinCallerReceive1
public:
class PinCallerReceive2
public:
class PinCallerReceive3
public:
} // PinCalls
// Arduino Board Declarations
namespace BoardDeclarations
namespace Types
typedef Mitov::ArduinoDigitalOutputChannel<
Mitov::ConstantProperty<22, bool, false >, // IsAnalog
Mitov::ConstantProperty<24, bool, false >, // IsCombinedInOut
Mitov::ConstantProperty<21, bool, false >, // IsOpenDrain
Mitov::ConstantProperty<26, bool, false >, // IsOutput
Mitov::ConstantProperty<20, bool, false >, // IsPullDown
Mitov::ConstantProperty<5, bool, true >, // IsPullUp
Mitov::ConstantProperty<23, bool, false >, // IsRawInput
Mitov::DigitalPin_EmbeddedPinImplementation<6, ::PinCalls::PinCallerReceive0 >, // OutputPin
6 // PIN
ArduinoDigitalChannel_6;
} // Types
namespace Instances
Types::ArduinoDigitalChannel_6 ArduinoDigitalChannel_6;
} // Instances
} // BoardDeclarations
// Declarations
namespace Declarations
namespace Types
typedef Mitov::BooleanInverter<
Mitov::ConstantProperty<4, bool, true >, // Enabled
Mitov::DigitalPin_EmbeddedPinImplementation<3, ::PinCalls::PinCallerReceive1 > // OutputPin
Inverter1;
} // Types
namespace Instances
Types::Inverter1 Inverter1;
} // Instances
namespace Types
typedef Mitov::UpDownCounter<
Mitov::TypedVariableMinMax<20, int32_t, ::ComponentVariables::Variable2, 0, 2147483647 >, // FCount
Mitov::ConstantProperty<6, int32_t, 1000 >, // InitialValue
Mitov::NestedProperty<14, Mitov::GenericValueLimit<
Mitov::ConstantProperty<13, bool, true >, // RollOver
Mitov::ConstantProperty<12, int32_t, 2147483647 > // Value
> >, // Value_Max
Mitov::NestedProperty<10, Mitov::GenericValueLimit<
Mitov::ConstantProperty<9, bool, false >, // RollOver
Mitov::ConstantProperty<8, int32_t, 0 > // Value
> >, // Value_Min
Mitov::TypedVariable<18, bool, ::ComponentVariables::Variable1 >, // NeedsUpdate
Mitov::TypedPin_EmbeddedPinImplementation<3, ::PinCalls::PinCallerReceive2, int32_t > // OutputPin
UpDownCounter1;
} // Types
namespace Instances
Types::UpDownCounter1 UpDownCounter1;
} // Instances
namespace Types
typedef Mitov::PulseGenerator<
Mitov::ConstantPropertyFloat<8, float, ::VisuinoConstants::FloatValue1 >, // Asymmetry
Mitov::ConstantPropertyFloat<17, float, ::VisuinoConstants::FloatValue1>, // FPhase
Mitov::TypedVariable<15, bool, ::ComponentVariables::Variable3 >, // FValue
Mitov::ConstantPropertyFloat<7, float, ::VisuinoConstants::FloatValue0 >, // Frequency
Mitov::ConstantProperty<5, bool, false >, // InitialValue
Mitov::DigitalPin_EmbeddedPinImplementation<3, ::PinCalls::PinCallerReceive3 >, // OutputPin
Mitov::ConstantPropertyFloat<9, float, ::VisuinoConstants::FloatValue1 >, // Phase
Mitov::NestedProperty<14, Mitov::TArduinoGeneratorWhenDisabled<
Mitov::ConstantProperty<13, bool, false >, // CompleteCycle
Mitov::ConstantProperty<12, bool, true >, // FCycleCompleted
Mitov::ConstantProperty<11, bool, false > // Reset
> > // WhenDisabled
PulseGenerator1;
} // Types
namespace Instances
Types::PulseGenerator1 PulseGenerator1;
} // Instances
namespace Types
typedef Mitov::StepperMotor4Wire<
Mitov::ConstantProperty<15, uint32_t, 0 >, // FLastTime
Mitov::TypedVariable<13, uint32_t, ::ComponentVariables::Variable4 >, // FStep
Mitov::ConstantProperty<12, bool, true >, // HalfStep
Mitov::DigitalPin_DirectBoardPinImplementation<8 >, // OutputPins_0
Mitov::DigitalPin_DirectBoardPinImplementation<9 >, // OutputPins_1
Mitov::DigitalPin_DirectBoardPinImplementation<10 >, // OutputPins_2
Mitov::DigitalPin_DirectBoardPinImplementation<11 >, // OutputPins_3
Mitov::ConstantProperty<5, bool, true >, // Reversed
Mitov::ConstantPropertyFloat<6, float, ::VisuinoConstants::FloatValue1 > // StepsPerSecond
Stepper1;
} // Types
namespace Instances
Types::Stepper1 Stepper1;
} // Instances
} // Declarations
// Type Converters
namespace TypeConverters
Mitov::Convert_BinaryToClock<Mitov::TypedVariable<0, bool, ::ComponentVariables::Variable5 >> Converter0;
Mitov::Convert_BinaryToClock<Mitov::TypedVariable<0, bool, ::ComponentVariables::Variable6 >> Converter1;
} // TypeConverters
namespace PinCalls
void PinCallerConverterReceive1( void *_Data );
void PinCallerConverterReceive2( void *_Data );
} // PinCalls
// Pin Call Implementations
namespace PinCalls
void PinCallerReceive0::Notify( void *_Data )
Declarations::Instances::Inverter1.InputPin_o_Receive( _Data );
void PinCallerReceive1::Notify( void *_Data )
TypeConverters::Converter0.Convert( _Data, PinCallerConverterReceive1 );
Declarations::Instances::UpDownCounter1.ResetInputPin_o_Receive( _Data );
void PinCallerReceive2::Notify( void *_Data )
Declarations::Instances::Stepper1.StepInputPin_o_Receive( _Data );
void PinCallerReceive3::Notify( void *_Data )
TypeConverters::Converter1.Convert( _Data, PinCallerConverterReceive2 );
Declarations::Instances::UpDownCounter1.DownInputPin_o_Receive( _Data );
} // PinCalls
namespace ComponentsHardware
void SystemUpdateHardware()
} // ComponentsHardware
//The setup function is called once at startup of the sketch
BoardDeclarations::Instances::ArduinoDigitalChannel_6.SystemInit();
Declarations::Instances::UpDownCounter1.SystemInit();
BoardDeclarations::Instances::ArduinoDigitalChannel_6.SystemStart();
Declarations::Instances::UpDownCounter1.SystemStart();
Declarations::Instances::PulseGenerator1.SystemStart();
// The loop function is called in an endless loop
BoardDeclarations::Instances::ArduinoDigitalChannel_6.SystemLoopBegin();
Declarations::Instances::PulseGenerator1.SystemLoopBegin();
Thanks. The task is quite small, reading a button and moving a stepper.
The code You posted is like shooting mosquitos with HIMARS....
Not doing much of real C## programming I'll not look into that massive stuff.
You managed to put in one button pressing and the stepping, What stops You from putting in a second button action and reverse stepping? Either You learn more about Visuino or learn how to write that output Yourself.
The application its going on can only have one button. Maybe it might be easier if i use a NO and NC switch then use two input pins and try and get it to step.
One button gives two states. One is On and one is Off. Code On for forward and Off for backward?
Using a switch makes what difference? The input reads either a HIGH or a LOW.
What stepper driver and stepper motor do you use? Data sheets, please.
Can you post a schematic. Hand drawn, photographed and posted is fine. Include all pin names/numbers, components, their part numbers and/or values and power supplies.
How about one press of the button and the motor moves forward a fixed nuimber of steps and stops then another press of the button and the motor reverses a fixed number of steps and stops. That could be easily done using the state change detection method and the MobaTools stepper library (using the Arduino IDE, I don't do Visuino).
Hello, sorry for the late reply all my family got a bug.
I need it to be one button operation, for example 500 steps one direction with button pushed, once button is released 500 steps in reverse. I'm not 100% sure on how many steps i currently need, i will need to experiment with it.
The steppers are 28byj-28 4 wire 5v
driver uln2003an
Arduino nano every
driver uln2003an
5v regulator
Steppers connected to pinws 8,9,10 and 11
push button is on GND to pin 6
Thank you
Here is a tested example that, I think, will do what you want to do. It uses the MobaTools stepper library and the state change detection method previously linked. Also Blink without delay() for timing.
Install the MobaTools library using the IDE library manager.
The example uses a NO push button switch attached to pin 6, wired to ground and the input pinMode is set to INPUT_PULLUP. The motor rotates 500 steps CW when the switch is pressed and stops until the switch is released. Upon release the motor rotates 500 steps CCW and stops until the switch is pressed again. Rinse, repeat.
#include <MobaTools.h>
const byte switchPin = 6;
// motor pins
const byte in1 = 8;
const byte in2 = 9;
const byte in3 = 10;
const byte in4 = 11;
MoToStepper stepper(2048, FULLSTEP);
  pinMode(switchPin, INPUT_PULLUP);
 stepper.attach( in1, in2, in3, in4 );
 stepper.setSpeed(100);
 stepper.setRampLen(5);
  static bool lastSwitchState = 0;
  static unsigned long timer = 0;
  unsigned long interval = 50;
  if(millis() - timer > interval)
     timer = millis();
     bool switchState = digitalRead(switchPin);
     if(switchState != lastSwitchState)
        if(switchState == LOW)
           stepper.move(500);
           stepper.move(-500);
        lastSwitchState = switchState;
If you absolutely must use Visuino, I suggest that you post your question in the Visuino forum.
Thank you so much for your help.
This is a project i'm working on for my disabled daughter to make a aid for her.
I tried Visuino just because was watching youtube :flushed: I have only just tried to learn Arduino.
I have copied in to Arduino IDE and getting this error message:-
WARNING: library MobaTools claims to run on avr, STM32F1, STM32F4, esp8266, esp32 architecture(s) and may be incompatible with your current board which runs on megaavr architecture(s).
In file included from C:\Users\Adrian\AppData\Local\Temp.arduinoIDE-unsaved202286-15576-17w2fyx.pskf\sketch_sep6a\sketch_sep6a.ino:1:0:
C:\Users\Adrian\Documents\Arduino\libraries\MobaTools\src/MobaTools.h:138:6: error: #error Processor not supported
In file included from C:\Users\Adrian\Documents\Arduino\libraries\MobaTools\src/MobaTools.h:162:0,
C:\Users\Adrian\Documents\Arduino\libraries\MobaTools\src/utilities/MoToBase.h:25:6: error: #error "Processor not supported"
exit status 1
Compilation error: exit status 1
Again thank you for your help
I have also just thought, i think i will have to fit a limit switch. If my daughter accidently double presses the button it will forse the stepper further than it can physically go.
Yes, unfortunately, the Nano Every is not yet supported by MobaTools. Work on it has already started, but at the moment I have a lot on my plate and cannot continue working on it.
ok no problem, thank you any way
I have made a bit of progress, i now have the stepper rotating different directions with just one button.
My issue now is i want to add limit switch, so when switchcw LOW dirstatus = 1 and switchstop = LOW dirstatus 3, i want the stepper to stop. I have put the two switches in one line but its not stopping the stepper? What do i need to add in?
Many thanks
int Pin1 = 8;//IN1 is connected to 10
int Pin2 = 9;//IN2 is connected to 11
int Pin3 = 10;//IN3 is connected to 12
int Pin4 = 11;//IN4 is connected to 13
int switchCW  =7;//define input pin for CW push button
int switchStop=6;//define input pin for Stop push button
int pole1[] ={0,0,0,0, 0,1,1,1, 0};//pole1, 8 step values
int pole2[] ={0,0,0,1, 1,1,0,0, 0};//pole2, 8 step values
int pole3[] ={0,1,1,1, 0,0,0,0, 0};//pole3, 8 step values
int pole4[] ={1,1,0,0, 0,0,0,1, 0};//pole4, 8 step values
int poleStep = 0;
int  dirStatus = 3;// stores direction status 3= stop (do not change)
 pinMode(Pin1, OUTPUT);//define pin for ULN2003 in1
 pinMode(Pin2, OUTPUT);//define pin for ULN2003 in2
 pinMode(Pin3, OUTPUT);//define pin for ULN2003 in3
 pinMode(Pin4, OUTPUT);//define pin for ULN2003 in4
 pinMode(switchCW,INPUT_PULLUP);// CW push button pin as input
 pinMode(switchStop,INPUT_PULLUP);//Stop push button pin as input
  if(digitalRead(switchCW) == LOW)
    dirStatus =1;
  }else if(digitalRead(switchCW) == HIGH)
   dirStatus  = 2;
  }else if(digitalRead(switchStop) == LOW && digitalRead(switchCW) == LOW)
    dirStatus =3;
 if(dirStatus ==1){
   poleStep++;
    driveStepper(poleStep);
 }else if(dirStatus ==2){
   poleStep--;
 }else{
  driveStepper(8);
 if(poleStep>7){
   poleStep=0;
 if(poleStep<0){
   poleStep=7;
 delay(1);
}// loop
void driveStepper(int c)
     digitalWrite(Pin1, pole1[c]);
     digitalWrite(Pin2, pole2[c]);
     digitalWrite(Pin3, pole3[c]);
     digitalWrite(Pin4, pole4[c]);
}//driveStepper end here
