stepper motor help me
My project light-sensitive automatic opening and closing curtains..stepper motor does not stop after 90 degrees
// This Arduino example demonstrates bidirectional operation of a
// 28BYJ-48, using a ULN2003 interface board to drive the stepper.
// The 28BYJ-48 motor is a 4-phase, 8-beat motor, geared down by
// a factor of 68. One bipolar winding is on motor pins 1 & 3 and
// the other on motor pins 2 & 4. The step angle is 5.625/64 and the
// operating Frequency is 100pps. Current draw is 92mA.
//declare variables for the motor pins
int motorPin1 = 2;    // Blue   - 28BYJ48 pin 1
int motorPin2 = 4;    // Pink   - 28BYJ48 pin 2
int motorPin3 = 3;    // Yellow - 28BYJ48 pin 3
int motorPin4 = 5;    // Orange - 28BYJ48 pin 4
 int sayi;
int sayii; // Red    - 28BYJ48 pin 5 (VCC)
int ldr = 0;
int ldr_value = 10;
int motorSpeed = 1200;  //variable to set stepper speed
int count = 0;          // count of steps made
int countsperrev = 256; // number of steps per full revolution
int lookup[8] = {B01000, B01100, B00100, B00110, B00010, B00011, B00001, B01001};
  //declare the motor pins as outputs
  pinMode(motorPin1, OUTPUT);
  pinMode(motorPin2, OUTPUT);
  pinMode(motorPin3, OUTPUT);
  pinMode(motorPin4, OUTPUT);
void loop(){
  if(ldr_value = analogRead(ldr))
     Serial.println(ldr_value);                 //prints the LDR values to serial monitor
  delay(10);
    clockwise();
  else if (count == countsperrev * 2)
    count = 0;}
  else{
    anticlockwise();
  count++;
//set pins to ULN2003 high in sequence from 1 to 4
//delay "motorSpeed" between each pin setting (to determine speed)
void anticlockwise()
  for(int i = 0; i < 8; i++)
    setOutput(i);
    delayMicroseconds(motorSpeed);
void clockwise()
  for(int i = 7; i >= 0; i--)
    setOutput(i);
void setOutput(int out)
  digitalWrite(motorPin1, bitRead(lookup[out], 0));
  digitalWrite(motorPin2, bitRead(lookup[out], 1));
  digitalWrite(motorPin3, bitRead(lookup[out], 2));
  digitalWrite(motorPin4, bitRead(lookup[out], 3));
I recommend using the motor shield
and AF_Motor library
And depending on how many steps is your stepper.
Most steppers are 48 steps
(48 steps = 360 degrees = 1 turn)
So 12 steps are 90 degrees
Try it, is the best way for precisely control
MSL:
The OP already has a ULN2003. Can you use the motor shield for that type of stepper motor?
saydin81:
I wonder if the series of IF and ELSE statements here does what you want. Work though it manually writing down the values so you can keep track.
  delay(10);
    clockwise();
    count = 0;}
  else{
    anticlockwise();
  count++;
...R
