Struggling to stop stepper motor for project after a loop
A simple project to finish. The project is simple, but I'm a complete beginner. It's about motorised blinds which automatically close when it is bright and open when it is dark. Thanks for any help
this is the code :
#include <Stepper.h>//Include the Arduino Stepper Library
const float STEPS_PER_REV = 32; // Number of steps per internal motor revolution
const float GEAR_RED = 64;// Amount of Gear Reduction
const float STEPS_PER_OUT_REV = STEPS_PER_REV * GEAR_RED;// Number of steps per geared output rotation
int StepsRequired;// Number of Steps Required
Stepper steppermotor(STEPS_PER_REV, 8, 10, 9, 11);
int photo; // sensor
// Nothing (Stepper Library sets pins as outputs for stepper motor)
pinMode(6,OUTPUT); // led blue
pinMode(5,OUTPUT); // led green
photo = analogRead(A1);
Serial.print("signal from sensor = " );
Serial.println(photo);
if (photo <250){
digitalWrite(6,HIGH); // blue led is on
digitalWrite(5,LOW);
StepsRequired = STEPS_PER_OUT_REV * 2 ; // Rotate CW 2 turns
steppermotor.setSpeed(1000);
steppermotor.step(StepsRequired);
delay(1000);}
else {
digitalWrite(6,LOW);
digitalWrite(5,HIGH);//green is on
StepsRequired = - STEPS_PER_OUT_REV * 2; // Rotate CCW 2 turns
//steppermotor.setSpeed(0);
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Hi, @michalganobis
Welcome to the forum.
What is the problem with the code you posted in post #1?
Have you developed this code in stages?
In other words;
Have you got code that JUST reads the sensor, please post link to data/specs.
Have you got code that JUST runs the stepper back and forth, please post a link to data/specs.
The idea is to prove your hardware individually before combining and trying to get it to work.
What does your Serial.print say in the IDE monitor, if you have a problem?
How are you powering your project?
Can you please post a circuit diagram, please no Fritzy images?
An image of a hand drawn schematic will be fine and include component names and pin labels.
Thanks.. Tom.. :grinning: :+1: :coffee: :australia:
hi
Firstly I try to use a dc motor in the project but probably need to add limit switches on both ends of the blinds to stop rotation, so I try with a stepper motor. But when I add on at the end of the circle 0 rotation motor stops responding for sensor change( LDR or PHOTO TRAN).thats my problem motor should wait for a change of signal? And then move opposite direction the same amount rotation.
driver board - ULN 2003 pin - 8,9,10,11 ; STEP MOTOR 28BYJ-48 ;LEDs -6,5 ,LDR pin A1
Any suggestion I will be delighted.
Thanks, michal
is a speed of 1000 rpm valid (1000*64*32 steps/sec). i've found that i can't step a motor faster than once / msec. why not try something much smaller and try increasing it.
unnecessary code suggests confusion about how things work
  • "Serial.begin()" should be called just once (not 3x) in setup.
  • there's no need for a 2nd analogRead() nor the additional prints
  • there's no need for the delays except possibly outside the if/else just to limit the # of prints
  • setSpeed() can be done once in setup
  • StepsRequired could be calculated just once and the argument to step() be StepsRequired or -StepsRequired
What is the device circled?
Please post an image of it please.
An LDR will need a different circuit to a phototransistor.
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
