Suggest parentheses around comparison in operand of '|' [-Werror=parentheses]
#include <Wire.h>
#include "EEPROM.h"
// Set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x27, 16, 2);
long duration, inches;
int lvl,m,sm,fulllvl,lowlvl,lowset,mode,dly,inch;
bool st,out;
pinMode(2, INPUT);
pinMode(4, OUTPUT);
pinMode(15, OUTPUT);
pinMode(34, INPUT);
pinMode(35, INPUT);
EEPROM.begin(4);
// initialize the LCD
lcd.begin();
// Turn on the blacklight and print a message.
lcd.backlight();
lcd.print("TANK LEVEL: 100%");
lcd.setCursor(0, 1);
lcd.print("MODE:A OUT:OFF");
mode=EEPROM.read(0);
lowset=EEPROM.read(1);
fulllvl=EEPROM.read(2);
lowlvl=EEPROM.read(3);
if(mode>1)mode=0;
if(lowset<10)lowset=10;
if(lowset>90)lowset=10;
if(fulllvl>100)lowlvl=0;
if(lowlvl>120)lowlvl=1;
dly++;
digitalWrite(4, LOW);
delayMicroseconds(2);
digitalWrite(4, HIGH);
delayMicroseconds(10);
duration = pulseIn(2, HIGH);
inches = microsecondsToInches(duration);
inch=inches-fulllvl;
lvl=(((lowlvl-inch))*100)/(lowlvl);
if(lvl<0)lvl=0;
if(lvl>100)lvl=100;
if( digitalRead(35)&digitalRead(34))st=0;
if( !digitalRead(34)&!st){
st=1;
if(m==0){m=1;
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(" MODE ");}
else if(m==2|m==1){
lcd.print(" ");
if(sm==0){sm=1;
else if(sm==1){sm=0;
if(m==1) EEPROM.write(0, mode);
else EEPROM.write(1, lowset);
EEPROM.commit();
else if(m==3){
fulllvl=inches;
lcd.setCursor(7, 1);
lcd.print(fulllvl);
EEPROM.write(2, fulllvl);
EEPROM.commit();
lcd.print(" ");
else if(m==4){
lowlvl=inch;
if(lowlvl<1)lowlvl=1;
lcd.print(lowlvl);
EEPROM.write(3, lowlvl);
EEPROM.commit();
lcd.print(" ");
else if(m==5){
m=0;
if( !digitalRead(35)&!st){
st=1;
if(m==0){
if(mode==1&lvl<99){out=!out; delay(500); }
else{
if(sm==0){m++;
if(m>5)m=1;
if(m==1)lcd.print(" MODE ");
if(m==2)lcd.print(" LOW LEVEL ");
if(m==3)lcd.print(" CALIBRATE FULL");
if(m==4)lcd.print(" CALIBRATE EMPTY");
if(m==5)lcd.print(" EXIT ");
}else{
if(m==1)mode++;
if(m==2)lowset+=10;
if(mode>1)mode=0;
if(dly>30){dly=0;
Serial.print("level ");
Serial.print(lvl);
Serial.print(" inch ");
Serial.println(inches);
if(lvl>99)out=0;
else if(mode==0&lvl<lowset)out=1;
if(m==0) {
lcd.setCursor(12, 0);
if(lvl<100)lcd.print(" ");
if(lvl<10)lcd.print(" ");
lcd.print(lvl);
lcd.setCursor(5, 1);
if(mode==0)lcd.print("ATO");
else if(mode==1)lcd.print("MAN");
lcd.setCursor(13, 1);
if(out)lcd.print("ON ");
else lcd.print("OFF");
else if(sm==1){
if(m==1) {
lcd.setCursor(6, 1);
}else if(m==2){
lcd.print(lowset);
digitalWrite(15,out);
delay(10);
long microsecondsToInches(long microseconds) {
return microseconds / 74 / 2;
this code
What about it?
It looks like you tried to use the correct formatting, :+1:
but it didn't quite work out. :frowning_face:
Please do try again.
This will help: "How to get the best out of this forum" - in particular, " Posting code and common code problems"
Please also post the full warning message - copy & paste, as for the code.
Typically the warning is an indication that what you coded may not what you meant due to precedence. In this case you probably meant || (logical or) rather than | (bitwise or).
full code change correction sir plz upload youvar comment
this code correction but new error
Compilation error: expected ';' before 'if'
I don't see a change.
And please, never ever change posted code after people have commented on it. Just post your updated code in a new reply.
Please read and follow post #3 !!!
Never post code as pictures.
post #3 code correction but new error
So post the code that's giving that error - using the <CODE/> button, as described.
Also post all the text from the 'Output' window - as for code: copy & paste the text and use the <CODE/> button.
The instructions are all in post #3.
There is no code in post #3. There is however the suggestion to read a topic how you should post code (using code tags).
For errors, right click in the output window, click 'copy all' and paste here in a reply (again using code tags).
[quote="karthikshop, post:1, topic:1177268, full:true"]
#include <Wire.h>
#include "EEPROM.h"
bool st,out;
pinMode(2, INPUT);
pinMode(4, OUTPUT);
pinMode(34, INPUT);
pinMode(35, INPUT);
EEPROM.begin(4);
lcd.begin();
lcd.backlight();
if(mode>1)mode=0;
dly++;
if(lvl<0)lvl=0;
if(lvl>100)lvl=100;
st=1;
if(m==0){m=1;
lcd.clear();
else if(m==2|m==1){
lcd.print(" ");
if(sm==0){sm=1;
EEPROM.commit();
else if(m==3){
fulllvl=inches;
lcd.print(fulllvl);
EEPROM.commit();
lcd.print(" ");
else if(m==4){
lowlvl=inch;
lcd.print(lowlvl);
EEPROM.commit();
lcd.print(" ");
else if(m==5){
m=0;
st=1;
if(m==0){
else{
if(sm==0){m++;
if(m>5)m=1;
}else{
if(m==1)mode++;
if(m==2)lowset+=10;
if(mode>1)mode=0;
if(dly>30){dly=0;
Serial.print(lvl);
if(lvl>99)out=0;
if(m==0) {
lcd.print(lvl);
else if(sm==1){
if(m==1) {
}else if(m==2){
lcd.print(lowset);
delay(10);
C:\Users\user\AppData\Local\Temp.arduinoIDE-unsaved2023912-11772-1jl1fs9.vsaf\sketch_oct12a\sketch_oct12a.ino: In function 'void loop()':
C:\Users\user\AppData\Local\Temp.arduinoIDE-unsaved2023912-11772-1jl1fs9.vsaf\sketch_oct12a\sketch_oct12a.ino:79:12: error: expected ';' before 'if'
'else' if(m==3){
C:\Users\user\AppData\Local\Temp.arduinoIDE-unsaved2023912-11772-1jl1fs9.vsaf\sketch_oct12a\sketch_oct12a.ino:90:5: error: expected '}' before 'else'
else if(m==4){
C:\Users\user\AppData\Local\Temp.arduinoIDE-unsaved2023912-11772-1jl1fs9.vsaf\sketch_oct12a\sketch_oct12a.ino:56:29: note: to match this '{'
C:\Users\user\AppData\Local\Temp.arduinoIDE-unsaved2023912-11772-1jl1fs9.vsaf\sketch_oct12a\sketch_oct12a.ino: At global scope:
C:\Users\user\AppData\Local\Temp.arduinoIDE-unsaved2023912-11772-1jl1fs9.vsaf\sketch_oct12a\sketch_oct12a.ino:111:2: error: expected unqualified-id before 'if'
C:\Users\user\AppData\Local\Temp.arduinoIDE-unsaved2023912-11772-1jl1fs9.vsaf\sketch_oct12a\sketch_oct12a.ino:136:1: error: expected unqualified-id before 'if'
if(dly>30){dly=0;
C:\Users\user\AppData\Local\Temp.arduinoIDE-unsaved2023912-11772-1jl1fs9.vsaf\sketch_oct12a\sketch_oct12a.ino:177:13: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\user\AppData\Local\Temp.arduinoIDE-unsaved2023912-11772-1jl1fs9.vsaf\sketch_oct12a\sketch_oct12a.ino:179:11: error: expected constructor, destructor, or type conversion before '(' token
delay(10);
C:\Users\user\AppData\Local\Temp.arduinoIDE-unsaved2023912-11772-1jl1fs9.vsaf\sketch_oct12a\sketch_oct12a.ino:180:1: error: expected declaration before '}' token
Using library Wire at version 2.0.0 in folder: C:\Users\user\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14\libraries\Wire
Using library LiquidCrystal I2C at version 1.1.2 in folder: C:\Users\user\Downloads\New folder\libraries\LiquidCrystal_I2C
Using library EEPROM at version 2.0.0 in folder: C:\Users\user\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14\libraries\EEPROM
exit status 1
You stubbornly ignore all hints on how to get help. And you are not willing to help us to help you. Didn't you read the advices linked in #3? It is really worth reading them thoroughly!
Take your time. It's worth it, and you'll get help much faster.
For which board are you compiling? If it's for an ESP8266, those are not the errors from the code in post #15. That code basically compiles for the Wemos D1 mini.
Which LiquidCrystal_I2C library are you using?
new error
Compilation error: 'microsecondsToInches' was not declared in this scope
How must we know what you did to cause that error. So now please learn that every time you make a change and you have problems, you post your code (in a new reply) using code tags. And to make it easier for you, the IDE developers have even added a function to the IDE (edit → copy for forum) to copy the code with code tags so you only have to paste it in a reply.
Deep sigh
i can t understand
arduino ide steps flow this code edit but this erroe
Compilation error: expression cannot be used as a function
hai brother whatsapp contect link & any contect other link
