Suitable battery/-ies for L298N motor driver & 12V dc gear motors w/ 915 rpm?
(deleted)
This topic has been moved here
What made you think that it had anything to do with suggestions for the Arduino project ?
Please be more careful in future
I'd probably use a rechargeable 4S 14.8V Lipo battery for the motor. An L298N drops quite a lot of the supplied voltage so you need around 15V to have a reasonable chance of getting 12V at the motor.
The battery capacity (mAh) needed will depend on how long you expect the motors to run for. And you'll need a proper Lipo charger too.
There are many other options even a 12V lead-acid battery may work.
Steve
(deleted)
(deleted)
@amethysthea - the next thing for you to learn about using the forum is not to put your replies inside the closing quote tag
