SWITCH to start and stop my datalogger
Hi.
I have made a datalogger with 3 thermocouples. Every thing is working fine.
My only problem is that, the code a using requires and serial input, i would like to have it by using a manual switch.
I have tried to make a control pin, and when it is HIGH i want it to datalog.
But i can't make it work.
Can any one help me?
// A simple data logger for the Arduino analog pins with optional DS1307
// uses RTClib from https://github.com/adafruit/RTClib
#include <SdFat.h>
#include <SdFatUtil.h>  // define FreeRam()
#define SD_CHIP_SELECT  SS  // SD chip select pin
#define USE_DS1307       0  // set nonzero to use DS1307 RTC
#define LOG_INTERVAL  1000  // mills between entries
#define SENSOR_COUNT     3  // number of analog pins to log
#define ECHO_TO_SERIAL   1  // echo data to serial port if nonzero
#define WAIT_TO_START    1  // Wait for serial input in setup()
#define ADC_DELAY       10  // ADC delay for high impedence sensors
// file system object
SdFat sd;
// Start and stop datalogging
int controlPin = 40;
// text file for logging
ofstream logfile;
// Serial print stream
ArduinoOutStream cout(Serial);
// buffer to format data - makes it eaiser to echo to Serial
char buf[80];
#if SENSOR_COUNT > 6
#error SENSOR_COUNT too large
#endif  // SENSOR_COUNT
// store error strings in flash to save RAM
#define error(s) sd.errorHalt_P(PSTR(s))
#if USE_DS1307
// use RTClib from Adafruit
// https://github.com/adafruit/RTClib
// The Arduino IDE has a bug that causes Wire and RTClib to be loaded even
// if USE_DS1307 is false.
#error remove this line and uncomment the next two lines.
//#include <Wire.h>
//#include <RTClib.h>
RTC_DS1307 RTC;  // define the Real Time Clock object
// call back for file timestamps
void dateTime(uint16_t* date, uint16_t* time) {
    DateTime now = RTC.now();
  // return date using FAT_DATE macro to format fields
  *date = FAT_DATE(now.year(), now.month(), now.day());
  // return time using FAT_TIME macro to format fields
  *time = FAT_TIME(now.hour(), now.minute(), now.second());
// format date/time
ostream& operator << (ostream& os, DateTime& dt) {
  os << dt.year() << '/' << int(dt.month()) << '/' << int(dt.day()) << ',';
  os << int(dt.hour()) << ':' << setfill('0') << setw(2) << int(dt.minute());
  os << ':' << setw(2) << int(dt.second()) << setfill(' ');
  return os;
#endif  // USE_DS1307
  pinMode(controlPin, INPUT);
  while (!Serial){}  // wait for Leonardo
  // pstr stores strings in flash to save RAM
  cout << endl << pstr("FreeRam: ") << FreeRam() << endl;
#if WAIT_TO_START
  while (digitalRead(controlPin) == HIGH){}
  delay(400);  // catch Due reset problem
#endif  // WAIT_TO_START
#if USE_DS1307
  // connect to RTC
  Wire.begin();
  if (!RTC.begin()) error("RTC failed");
  // set date time callback function
  SdFile::dateTimeCallback(dateTime);
  cout  << now << endl;
  // initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
if (!sd.begin(SD_CHIP_SELECT, SPI_SIXTEENTH_SPEED))sd.initErrorHalt();
  // create a new file in root, the current working directory
  char name[] = "LOGGER00.CSV";
  for (uint8_t i = 0; i < 100; i++) {
    name[6] = i/10 + '0';
    name[7] = i%10 + '0';
    if (sd.exists(name)) continue;
    logfile.open(name);
  if (!logfile.is_open()) error("file.open");
  cout << pstr("Logging to: ") << name << endl;
  // format header in buffer
  obufstream bout(buf, sizeof(buf));
  bout << pstr("millis");
#if USE_DS1307
  bout << pstr(",date,time");
  for (uint8_t i = 0; i < SENSOR_COUNT; i++) {
    bout << pstr(",sens") << int(i);
  logfile << buf << endl;
#if ECHO_TO_SERIAL
  cout << buf << endl;
#endif  // ECHO_TO_SERIAL
  uint32_t m;
  // wait for time to be a multiple of interval
  do {
    m = millis();
  } while (m % LOG_INTERVAL);
  // use buffer stream to format line
  // start with time in millis
  bout << m;
#if USE_DS1307
  bout << ',' << now;
  // read analog pins and format data
  for (uint8_t ia = 0; ia < SENSOR_COUNT; ia++) {
#if ADC_DELAY
    analogRead(ia);
    delay(ADC_DELAY);
#endif  // ADC_DELAY
    bout << ',' << analogRead(ia);
  bout << endl;
  // log data and flush to SD
  logfile << buf << flush;
  // check for error
  if (!logfile) error("write data failed");
#if ECHO_TO_SERIAL
  cout << buf;
  // don't log two points in the same millis
  if (m == millis()) delay(1);
  if (!Serial.available()) return;
  logfile.close();
  cout << pstr("Done!");
  while (1);
The switch is wired some mysterious way.
The code does something. You haven't told us what.
You want the code to do something. You haven't told us what.
Given what you have left out? No.
I think you misunderstand me.
I have a on-of button connected to 5 V, and then back to digitalpin 40.
When digital pin reads 5V, i want my datalogger start logging.
Before i tried to make this on-of button, i was activated with my serialport just giving it any input.
Best regards Bastian Gaardahl Christensen
BastianGaardahl:
I think the logic is reversed here, you loop (wait) as long as the pin is high. So to start, you have to apply a "low" (ground) to the pin. If you have not attached a resistor (~47kOhm) from the pin to ground, it will probably stay high when you switch off (disconnect) your switch from 5V and it will never start.
Why don't you use a momentary switch/push button, debounce and a state variable to keep track of ON state and OFF state; and pause/resume data logging based on the state of the variable?
This can perhaps help: http://arduino.cc/en/Tutorial/Debounce
