Hi
I tried to run motor drive TB6612FNG and it's not working and I have no clue why
I attached the code and the schematic
TB6612FNG H-Bridge Demo
TB6612-Demo.ino
Demonstrates use of TB6612FNG H-Bridge Motor Controller
Drives two DC MotorsDroneBot Workshop 2019
https://dronebotworkshop.com
*/int stby = 6;
// Motor Aint pwmA = 5;
int in1A = 3;
int in2A = 4;// Motor B
int pwmB = 6;
int in1B = 7;
int in2B = 8;// Speed control potentiometers
int SpeedControl1 = A0;
int SpeedControl2 = A1;// Motor Speed Values - Start at zero
int MotorSpeed1 = 0;
int MotorSpeed2 = 0;void setup()
// Set all the motor control pins to outputs
pinMode(stby, OUTPUT);
pinMode(pwmA, OUTPUT);
// pinMode(pwmB, OUTPUT);
pinMode(in1A, OUTPUT);
pinMode(in2A, OUTPUT);
// pinMode(in1B, OUTPUT);
// pinMode(in2B, OUTPUT);}
static int counter = 0;
Serial.println(counter++);// Set Motor A forward
digitalWrite(stby, HIGH);
digitalWrite(in1A, HIGH);
digitalWrite(in2A, LOW);// Set Motor B forward
// digitalWrite(in1B, HIGH);
// digitalWrite(in2B, LOW);// Read potentiometers and convert to range of 0-255
// MotorSpeed1 = map(analogRead(SpeedControl1), 0, 1023, 0, 255);
// MotorSpeed2 = map(analogRead(SpeedControl2), 0, 1023, 0, 255);// Set the motor speeds
analogWrite(pwmA, 125);
// analogWrite(pwmB, MotorSpeed2);
Thanks!!!
