I was wondering if someone could recommend me a Canadian link to terminal connectors for the image below:
As you see the wires have to be connected from a pre-existing wire, and I was told that I need terminal connectors, but I couldn't find the one that would work for this schematic. Thank you for your help.
LarryD
May 20, 2022, 12:45am
2
For shorter LED strips use (polarized) Dupont headers.
For longer strips, recommend you use 3-Pin JST SM connectors.
JCA34F
May 20, 2022, 12:55am
4
I don't think these work work for me because none of my connections use a barrel plug.
Can someone please supply me a link for the image below? I was unable to find it online. I live in Canada so I need Canadian links. Thanks.
LarryD
May 20, 2022, 1:19am
10
Canada here too :) .
Here is the PDF that the image came from:
You can also solder things as shown in this post:
Pinch Clamps Make Joining Wire an Easy Task
The Pinch clamps discussed for holding PCBs are great when you need to join two or more wires together.
The following images show the method.
If you use 2 pinch clamps, you can still join 3 wires, just hold 2 of the wires with one pinch clamp.
[A]
[B]
[C]
[D]
[E]
[F]
[G]
