TFMini S no output on Arduino Mega
Hello! I'm encountering a problem obtaining data from TFMini S using Arduino Mega. The code is running but shows no output on the serial monitor. I have tried using different pins but the outputs are still not showing.
#include <SoftwareSerial.h>
#include "TFMini.h"
// Setup software serial port
SoftwareSerial mySerial(18, 19);  // Uno RX (TFMINI TX), Uno TX (TFMINI RX)
TFMini tfmini;
  // Step 1: Initialize hardware serial port (serial debug port)
  // wait for serial port to connect. Needed for native USB port only
  while (!Serial)
  Serial.println("Initializing...");
  // Step 2: Initialize the data rate for the SoftwareSerial port
  mySerial.begin(TFMINI_BAUDRATE);
  // Step 3: Initialize the TF Mini sensor
  tfmini.begin(&mySerial);
  // Take one TF Mini distance measurement
  uint16_t dist = tfmini.getDistance();
  uint16_t strength = tfmini.getRecentSignalStrength();
  // Display the measurement
  Serial.print(dist);
  Serial.print(" cm      sigstr: ");
  Serial.println(strength);
  // Wait some short time before taking the next measurement
  delay(25);
The code is an example from the TFmini library.
TFMini_BAUDRATE is 115200. Last I checked SoftwareSerial isn't that fast.
It's a Mega, right? Use hardware Serial1. It will do 115200 baud.
