TFT (ILI9341 ) & SD conflict
I have a project that need to use SD card and TFT display. I used a Mini Pro and a 2.2" TFT with
ILI9341 driver.
I found that both the Mini Pro and the TFT can work at 3.3 volt, they can connect directly and don't
need 4050 as interface.
I followed the pin connections in :
http://www.seeedstudio.com/wiki/2.8''_TFT_Touch_Shield_V2.0
D4 : RESET (TFT), CS (SD)
D5 : CS (TFT)
D6 : D/C (TFT)
D7 : LED (TFT)
D11 : MOSI(TFT & SD)
D12 : MISO (TFT & SD)
D13 : SCK (TFT & SD)
I tried the TFTv2 library examples ( GitHub - gmtii/ili9341-arduino: ILI9341 2.2 LCD library ) and the Arduino SD
examples, they are all ok.
But When I tried to combined both SD codes & TFT codes together, it seems that SD or TFT cannot
used together at the same time.
e.g.
// --- The following codes work ok, it can serial out the text file and draw on TFT -----
#include <TFTv2.h>
#include <SPI.h>
#include <SD.h>
const int chipSelect = 4;
  Serial.print("Initializing SD card...");
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(10, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  Serial.println("card initialized.");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("Textfile.txt");
  // if the file is available, write to it:
  if (dataFile)
    while (dataFile.available()) {
      Serial.write(dataFile.read());
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening datalog.txt");
    TFT_BL_ON;      // turn on the background light
    Tft.TFTinit();  // init TFT library
    Tft.drawChar('S',0,0,1,RED);                // draw char: 'S', (0, 0), size: 1, color: RED
    Tft.drawChar('E',10,10,2,BLUE);             // draw char: 'E', (10, 10), size: 2, color: BLUE
    Tft.drawChar('E',20,40,3,GREEN);            // draw char: 'E', (20, 40), size: 3, color: GREEN
    Tft.drawChar('E',30,80,4,YELLOW);           // draw char: 'E', (30, 80), size: 4, color: YELLOW
    Tft.drawChar('D',40,120,4,YELLOW);          // draw char: 'D', (40, 120), size: 4, color: YELLOW
    Tft.drawString("Hello",0,180,3,CYAN);       // draw string: "hello", (0, 180), size: 3, color: CYAN
    Tft.drawString("World!!",60,220,4,WHITE);    // draw string: "world!!", (80, 230), size: 4, color:
WHITE
    dataFile.close();
//-------------------------------- End of program --------------------------------------------------
But once I changed to display something to TFT, then run some SD functions , the TFT screen will be
erased and white screen. It seems that the problem is RESET(TFT) and CS(SD) are both connect to D4
and they have conflict !
//----------- conflict program ! -------------------------------------------------------------------------
    return;
WHITE
  if (dataFile)
  else {
    dataFile.close();
//--------------------------------- End of Program ----------------------------------------------------
Does anyone know how to solve this problem ?
Thanks in advance !
please edit your post and put the code inside [ code] [ /code] tags like this:
code here
Hi KK959,
I have an screen with that chipset the ILI9341, mine is from elecfreaks trough dealextreme, i have tried all connections but I have not had any response from the times I tried. how you connected the screen, i imported the library from GitHub (UTFT v2) and tried the libraries from elecfreaks but it seems that code don´t says anything to my screen.
Please tell me how you do that.
Regards
KK959:
Every time you access the SD card the screen will reset. Yes, that would be a problem.
KK959:
Move CS to a different pin
XarlyX:
They don't work on a 5V Arduino.
http://forum.arduino.cc/index.php?topic=181679.0
I'd move the TFT CS to pin 10, which is the one normally used for SPI, and leave
pin 4 as SD CS. It will then be compatible with the Due pinout (SPI is restricted to
pins 4 and 10 for CS).
MarkT:
He said " It seems that the problem is RESET(TFT) and CS(SD) are both connect to D4 "
the VCC pin of my screen goes to the 3,3v arduino pin. so i think that my arduino also works sending +3.3 volts.
i have read all the arduino.cc posts referring to this screen and everyone says always the same
Screen only works with +3.3v
and all the pepole finally get the screen working correctly so where is my error mr. fungus?
i'm gonna remake my question
I have seen a group of youtube videos in where the users have the same screen and they show icons, photos or animations (of processing) and every time i make a question the response is the same "get the libraries from GitHUB and connect like this" in which results are the same a) a completely blue screen b) a full white screen.
please make to me a graphic of the connections and the code (like an example) for check that my screen is OK
Thx
XarlyX:
Well ... it you follow the link I posted you might find out.
Hint: It's not just connecting VCC to 3.3V - that's the ONLY pin that can be connected to 5V (the screen has a voltage regulator on VCC)
Sorry Fungus but i don't understand you, in this link you have posted (which I have read over thirty times) all I see is that an user is using an IC so what I should be reading in the link
XarlyX:
Maybe you should be using an IC as well.
Dear,
I had the same problem like you so I register account to reply but dont know why can not post on the forum.
The problem is SDCard library.
You should not use the example which declare
SDFile root;
Instead
File root.
CODE: havent check yet, hope this helps!
SdFile root; //this one will reset your lcd everytime!
File root2; // this one will not reset, but it flick your display, makes image quality is terrible. I havenot found and solution to fix yet.
void setup(void) {
if (!SD.begin(4)) {
Serial.println("initialization failed!");
return;
root2 = SD.open("/");
printDirectory(root2, 0);
void printDirectory(File dir, int numTabs) {
while (true) {
File entry = dir.openNextFile();
if (! entry) {
// no more files
for (uint8_t i = 0; i < numTabs; i++) {
Serial.print('\t');
Serial.print(entry.name());
if (entry.isDirectory()) {
Serial.println("/");
printDirectory(entry, numTabs + 1);
// files have sizes, directories do not
Serial.print("\t\t");
Serial.println(entry.size(), DEC);
entry.close();
KK959:
ILI9341 driver.
D5 : CS (TFT)
D6 : D/C (TFT)
D7 : LED (TFT)
e.g.
#include <TFTv2.h>
#include <SPI.h>
#include <SD.h>
   return;
 if (dataFile)
 else {
WHITE
dataFile.close();
   return;
WHITE
 if (dataFile)
 else {
   dataFile.close();
Thanks in advance !
