Tft touch screen and serial data
I have been checking serial data sent when a TFT touch screen touch pad is pressed or not pressed.
In the sketch I have loaded, the serial monitor shows a steady stream of -1,-1 when it enters the first function "First Screen" as its waiting for a keypress.
When I select "Next Screen", it goes into that function but there is no serial data shown after the 228,142 keypress from the previous screen, even though there is a key press waiting called "Exit".
When I press "Exit", it goes back to "First Screen" and the serial data -1,-1 starts streaming again.
I commented out the Serial.print in the first function incase it over-rode the serial.print in the second function, but there is still no serial data streaming in the second function.
Is this normal?? If not, can I somehow prevent the constant streaming and only show the serial data when a keypad area is pressed.?
Code below
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
#include <URTouch.h>
MCUFRIEND_kbv tft;
#define BLACK 0x0000
#define NAVY 0x000F
#define DARKGREEN 0x03E0
#define DARKCYAN 0x03EF
#define MAROON 0x7800
#define PURPLE 0x780F
#define OLIVE 0x7BE0
#define LIGHTGREY 0xC618
#define DARKGREY 0x7BEF
#define BLUE 0x001F
#define GREEN 0x07E0
#define CYAN 0x07FF
#define RED 0xF800
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define ORANGE 0xFD20
#define GREENYELLOW 0xAFE5
#define PINK 0xF81F
int x;
int y;
URTouch  myTouch( 52, 53, 51, 50, 44);  //(for hardware SPI)
  Serial.begin(115200); //Use serial monitor for debugging
  tft.reset();
  tft.begin(0x9488);
  myTouch.InitTouch(1);//0 = portrait  1= landscape
  myTouch.setPrecision(PREC_MEDIUM);
  tft.setRotation(1);  //0 Landscape
  tft.fillScreen(BLACK);
  FirstScreen();
void FirstScreen()
  tft.setCursor(140, 20);
  tft.setTextSize(3);
  tft.setTextColor(WHITE);
    tft.print ("First Screen");
    tft.fillRect(140,150,250,75,WHITE);
    tft.setCursor(150,160);
    tft.setTextColor(BLACK);
    tft.print("Next SCreen");
    while (true)
    if (myTouch.dataAvailable())
      delay(100);
      myTouch.read();
      x = myTouch.getX(); //was x
      y = myTouch.getY(); //was y
      Serial.print(x); Serial.print(","); Serial.println(y);
      if (x < 360 && x > 145)
        if (y > 100 && y < 160)
          NextScreen();
void NextScreen()
  tft.setCursor(105, 10);
  tft.setTextSize(3);
  tft.print(" Next Screen");
  tft.setCursor(400, 300);
  tft.setTextSize(3);
  tft.print("Exit");
  while (true)
      myTouch.read();
      x = myTouch.getX();
      y = myTouch.getY();
      Serial.print(x); Serial.print(', '); Serial.println(y);
      if (x < 460 && x > 400)
        if ( y > 10 && y < 30)
          FirstScreen();
This delay statements looks mis-placed, and means the block { } after this will run every time.
Maybe...
  delay(100);
Thanks very much for your reply. You were 100% correct. I misplaced the delay statement.
Problem is no longer there.
I’ll call this a fix!
Good to hear... feel free to check the "Solution" box on the post so other readers know.
Done. Thanks again for your help.
In future, please do everybody a favour and post code using code tags as described in How to get the best out of this forum. It makes it easier to read, easier to copy and prevents the forum software from incorrect interpretation of the code.
//Edit
I can now see that you tried but it did not work out as expected :wink: It's the </> button, not a text.
I used the </> tags as I was told to do as you observed in your edited post.
Do us a favour and look first before posting a somewhat unfavourable post..
Please look at your post #1.
Please edit #1 by removing the existing "code".
Then click the </> icon.
Copy-paste from your working sketch to the new "code window".
Seriously, it makes the Forum work much better when we have code in "code windows".
You don't need to click icon then copy-paste.
You can always copy-paste. highlight the code. then click </> icon.
Both methods work.
David.
Thanks for a helpful reply David. There are some people on this forum who would do themselves a favour by seeing how to post a constructive rather than destructive reply.
