Hello,
i need replace of this model of display or alternative compatible, some one can help me?
or say me where i can find?
thanks you for all
I am unfamiliar with the word "sostituite", as I imagine others are as well, and have no idea what it is you are asking.
Have you tried visiting the website whose address is prominently displayed on the back of that board to find whatever information it is you are after?
The same LCD can be found in:
Google told me that this is "to substitute" (replace)
@nicopaglia
Why do you think you need to replace the screen?
yes sorry, maybe correct word is replaced or alternative.
thanks you
yes I looked at the website and it is stuck in 2012, and I didn't even find a datasheet about it
Have you tried LCD wiki?
but why you need to replace the screen? Was the old screen broken?
i work for a company, i need to produce some unit for old client.
if some one can help us we can pay it for support.
thanks you
i look, but i don't find the correct model, the biggest problem is i don't have the datasheet of the original model
thanks you
yes, is the same model, but there is no solution for a replace
thanks you
How about this one:
it can be correct, but how i can check the connection between the two model?
thanks you
What the solution do you expect from the forum? The only way for you is to change the code and schematic to adapt it for a new display.
all similar displays have the same set of pins and are connected in the same way. you don't even need to look for a display of the same model
Do you have a source code for the old project?
yes, it can be the last solution... but is possible from the compile file make reverse engineering ?
no i don't have,i have only compile file
No, it is impossible
In case if the source is not available, the task becomes much more complicated. In this case, you need a display that is as similar as possible to the one used in the project earlier.
Not necessarily the same model - but the same size, with the same interface and the same controller.
ok i understand, thanks you
