The drop servo is not working why
#include <Servo.h>
Servo pickServo;
Servo dropServo;
#define S0 4
#define S1 5
#define S2 7
#define S3 6
#define sensorOut 8
int frequency = 0;
int color=0;
int detectColor() {
  // activating red photodiodes to read
  digitalWrite(S2, LOW);
  digitalWrite(S3, LOW);
  frequency = pulseIn(sensorOut, LOW);
  int R = frequency;
  Serial.print("Red = ");
  Serial.print(frequency);//printing RED color frequency
  Serial.print("   ");
  delay(50);
   // activating blue photodiodes to read
  digitalWrite(S3, HIGH);
  int B = frequency;
  Serial.print("Blue = ");
  Serial.println("   ");
  // activating green photodiodes to read
  digitalWrite(S2, HIGH);
  // Reading the output frequency
  int G = frequency;
  Serial.print("Green = ");
  Serial.print("   ");
  delay(50);
  delay(50);
//Readings are different for different setup
//change the readings according your project and readings detected
  if(R<22 & R>20 & G<29 & G>27){
    color = 1; // Red
    Serial.print("Detected Color is = ");
    Serial.println("RED");
  if(G<25 & G>22 & B<22 &B>19){
    color = 2; // Orange
      Serial.println("Orange  ");
  if(R<21 & R>20 & G<28 & G>25){
    color = 3; // Green
    Serial.println("GREEN");
  if(R<38 & R>24 & G<44 & G>30){
    color = 4; // Yellow
    Serial.println("YELLOW");
  if (G<29 & G>27 & B<22 &B>19){
    color = 5; // Blue
    Serial.println("BLUE");
  return color;
  pinMode(S0, OUTPUT);
  pinMode(S1, OUTPUT);
  pinMode(S2, OUTPUT);
  pinMode(S3, OUTPUT);
  pinMode(sensorOut, INPUT);
  //frequency-scaling to 20% selected
  digitalWrite(S0, LOW);
  digitalWrite(S1, HIGH);
  pickServo.attach(9);
  dropServo.attach(10);
  //initial position of servo motor
  pickServo.write(115);
  delay(600);
  for(int i = 115; i > 65; i--) {
    pickServo.write(i);
    delay(2);
  //read color values by calling function. save the values for conclusion in variable
  color = detectColor();
  switch (color) {
    case 1:
    dropServo.write(50);
    case 2:
    dropServo.write(80);
    case 3:
    dropServo.write(110);
    case 4:
    dropServo.write(140);
    case 5:
    dropServo.write(170);
    case 0:
  for(int i = 65; i > 29; i--) {
    pickServo.write(i);
    delay(2);
  delay(300);
  for(int i = 29; i < 115; i++) {
    pickServo.write(i);
    delay(2);
  color=0;
Topic moved. Please do not post in "Uncategorized"; see the sticky topics in Uncategorized - Arduino Forum.
I was trying to build a color sorting machine but the drop servo does not work
#include <Servo.h>
Servo pickServo;
Servo dropServo;
#define S0 4
#define S1 5
#define S2 7
#define S3 6
#define sensorOut 8
int frequency = 0;
int color=0;
int detectColor() {
  int R = frequency;
  Serial.print("   ");
  delay(50);
  int B = frequency;
  int G = frequency;
  Serial.print("   ");
  delay(50);
  delay(50);
    color = 1; // Red
    color = 3; // Green
    color = 5; // Blue
  return color;
  delay(600);
    pickServo.write(i);
    delay(2);
  switch (color) {
    case 1:
    case 2:
    case 3:
    case 4:
    case 5:
    case 0:
    pickServo.write(i);
    delay(2);
  delay(300);
    pickServo.write(i);
    delay(2);
  color=0;
I did already move your topic so there is no reason to start a second topic. I've merged the two topics on the same subject.
This is called cross-posting and it wastes people's time.
That is a very poor description of the problem
Please give more details
the servo motor that is used to control the dropping mechanism is not working after color sensor senses a color it must move a at angle specified for the color but it doesn't move and when i test the servo motor only it worked
switch (color) {
    case 1:
        dropServo.write(50);  // Drop position for RED
    case 2:
        dropServo.write(80);  // Drop position for ORANGE
    case 3:
        dropServo.write(110); // Drop position for GREEN
    case 4:
        dropServo.write(140); // Drop position for YELLOW
    case 5:
        dropServo.write(170); // Drop position for BLUE
    case 0:
        break; // No action for color 0
Describe "is not working"
it is not moving to the angle i specified for the servo motor when the color sensor detect a color it is always the same angle for every color the color sensor detects
Print the value of color immediately before you use it in the switch statement.
It looks OK, but you shoukd try to avoid having local variabkes with the same beams as global variables, and you seem to be a bit confused about a getting a return value from a function.
I did say it looks OK, but it's harder to tell.
Either use a global variable, or use the return value from the function in which case there is no need for a global variable.
Now it don't make much difference, but as things grow, avoiding global variables will become a Good Idea.
a7
Use “&&” instead of “&” here and in your other if’s
Verify your servo code is writing to the correct pin, the servo wires are connected to the right pin, and the power supply is sufficient for two servo motors. Even when "stopped", both servos use power.
if((G > 22 &&  G < 25) && (B > 19 && B <22)){
