Still stuck on 1.8.x until the UI becomes a usable interface.
Running windows 11, install out of the box, no user prefs set, context menus are way over to the right with min, max and close buttons on top, also verify and upload buttons remain unresponsive to clicks. Like I said, no amendments to the default install have been made, direct from download>install.
Hi @negativ3 . The Arduino IDE developers are tracking the bug here:
opened 04:20PM - 21 May 24 UTC
topic: code
type: imperfection
### Describe the problem
Whenever I create a new sketch, the "File,Edit,Sketch,… Tool, Help" menu is incorporated into the "verify, upload and debug" menu, rendering some parts unavailable and the window cannot be moved:
This is accompanied by a dialog that says:
> A setting has changed that requires a restart to take effect.
> Press the restart button to restart Arduino IDE and enable the setting.
If The "**RESTART**" button in the dialog is pressed, the menu bar on the current sketch is placed in the same situation as above.
At first, a couple of clicking on new sketch would solve the problem. Now, it is constant.
### To reproduce
do not think you can reproduce.
### Expected behavior
to work properly
### Arduino IDE version
- 2.3.2
- latest nightly build
### Operating system
Windows
### Operating system version
10
### Additional context
Discussion:
https://forum.arduino.cc/t/ide-2-3-2-issue/1262578
#### Additional reports
- https://github.com/arduino/arduino-ide/issues/2680
- https://github.com/arduino/arduino-ide/issues/2744
- https://forum.arduino.cc/t/a-setting-has-changed/1167019/1
- https://forum.arduino.cc/t/a-setting-has-changed/1167019/3
- https://forum.arduino.cc/t/a-setting-has-changed/1167019/20
- https://forum.arduino.cc/t/the-ide-asks-me-to-restart-and-then-it-locks-up/1171063
- https://forum.arduino.cc/t/problem-with-ide2-1/1193160/1
- https://forum.arduino.cc/t/problem-with-ide2-1/1193160/14
- https://forum.arduino.cc/t/funky-title-bar-after-reset/1248431
- https://forum.arduino.cc/t/ide-2-3-2-issue/1262578
- https://forum.arduino.cc/t/many-background-tasks-with-ide2-3-2/1263835
- https://forum.arduino.cc/t/cannot-move-ide-2-3-2-sketch-window-between-monitors-on-win10/1276812/5
- https://forum.arduino.cc/t/cannot-move-ide-2-3-2-sketch-window-between-monitors-on-win10/1276812/8
- https://forum.arduino.cc/t/should-we-still-report-and-check-for-semi-minor-issues-and-annoyances/1290531/6
- https://forum.arduino.cc/t/problem-with-the-ide-interface/1293258
- https://forum.arduino.cc/t/ide-top-level-menu-dissapeared-after-update/1322395/1
- https://forum.arduino.cc/t/ide-top-level-menu-dissapeared-after-update/1322395/7
- https://forum.arduino.cc/t/ide-not-opening-correctly/1332053
- https://forum.arduino.cc/t/ide-2-3-4-issue/1346166
- https://forum.arduino.cc/t/arduino-ide-2-3-6-is-now-available/1371936/20
- https://forum.arduino.cc/t/odd-page-when-i-open-up-the-ide/1373083
- https://forum.arduino.cc/t/ide-loses-top-bar-will-not-close/1386361
- https://forum.arduino.cc/t/arduino-ui-broken-and-unuseable/1390458
- https://forum.arduino.cc/t/ide-2-3-x-versions-hardly-usable/1399626
#### Related
- https://github.com/arduino/arduino-ide/issues/2716
- https://forum.arduino.cc/t/solved-linux-appimage-2-3-2-no-menu-unable-to-save-sketch/1242394
- https://forum.arduino.cc/t/toolbar-disappeared-in-linux/1265437
<details>
<summary><b>Keywords</b></summary>
<p>
- "custom"
- "window.titleBarStyle"
- "native"
</p>
</details>
### Issue checklist
- [X] I searched for previous reports in [the issue tracker](https://github.com/arduino/arduino-ide/issues?q=)
- [X] I verified the problem still occurs when using the latest [nightly build](https://www.arduino.cc/en/software#nightly-builds)
- [X] My report contains all necessary details
If you have a GitHub account, you can subscribe to that thread to get notifications of any new developments related to this subject:
Please only comment on the GitHub issue thread if you have new technical information that will assist with the resolution. General discussion and support requests are always welcome here on the Arduino Forum.
