Touch panel to Arduino
Dears,
I have this touch panel with 12 button, the panel connected to 14 pins; the first one and last one are same and connected to gather like a common pin and the other pins from 2 to 13 are belongs to each button (1 pin for each button)
This touch panel is working with 5v.
How I can get the touch event? I tried using push button code but unfortunately nothing received to the Serial, Please some help or advise.
Number the pins from left to right 0 - 13.
Pin 0 - Read left six buttons
Pin 1 - left side upper left
Pin 2 - left side middle left
Pin 3 - left side lower left
Pin 4 - left side lower right
Pin 5 - left side middle right
Pin 6 - left side upper right
Pin 7 - right side middle left
Pin 8 - right side upper left
Pin 9 - right side lower left
Pin 10 - right side lower right
Pin 11 - right side middle right
Pin 12 - right side upper right
Pin 13 - Read right 6 buttons
I think that's it. Then just use it like a 2X6 membrane keypad. There are many keypad threads on the forum. If anyone knows of a particularly good one and wants to link it that would help.
Care to share the Web link describing the panel?
Get your multimeter and measure the resistance between the common connection and a given touch pad when pressed.
Thank you so much for your reply.
I tried to find out any 2X6 keypad code but unfortunately no results.
Do you have a code for it?
Sorry for annoying you but I still new in Arduino.
Unfortunately no description for this panel, I contacted the factory but no response yet.
You'll have to modify some existing keypad code.
Noted.
I will try my best, and if I need some help I will reply to you, thank you so much really appreciated.
That's the best way to get help.
After testing today using the keypad library unfortunately nothing works as expected.
If you take a look at the touch panel; the pin1 and pin13 are connected together as beginning and end.
The other pins are the buttons.
The biggest problem is I don't know the schematic diagram of the touch panel.
Any advise please?
Use a continuity tester.
Sounds like dali to me
The continuity test results giving nothing.
Dali?
What do you mean by dali?
By the way I have a picture for the board where the touch panel connected.
Each pin connected to resistor then
to the microcontroller even the common pins 0 and 13 are connected together then to resistor. What is the appropriate code for this?
2k2 resistors. Hmmm.
I notice that what you did not show us in the initial post was that this panel is already attached to a connector that mounts on those header pins.
It had better be, as if it is no longer attached to that connector it is clearly useless.
So you need to plug that connector on the end of the panel cable to a pin header (or at least one piece of pin header with a few pins at each end) so you can verify with your multimeter that you do actually get continuity (a few Ohms) between the end pins and (then) between one of those pins and measure the resistance to one or more of the "touch" pads when you press them.
Dears,
I really stocked in this.
the current situation; I connected the the first pin and last pin to the machine itself; and I tried to read any of the pins using digitalread but no success, then I opened the datasheet of the microcontroller that attached to the board (PIC24FJ256GB110/ 100 pins) then I found that the pins are connected to the microcontroller using Schmitt trigger, and it's really complicated for me. so if anybody can help I'll be appreciated; at least 1 pin that's enough for me.
Do you have an ohmmeter ?
Yes I have.
So then use it.
You'll have to label the 'pins' and beep it out, methodically check for continuity results from each 'button'.
