I made up a little circuit (see attach.) with a piezo disc and a 555 timer that will use to trigger an external interrupt. The circuit works, i.e. the piezo triggers the 555 timer but I was wondering if there is a simpler (fewer components) circuit for triggering a 555 IC with a piezo element?
if I take out the zener the spikes go to 20V and over, I don't know if that's good for the 555 trigger pin. I'm hitting the piezo pretty hard, tapping tempo. I've tried different resistor values for R1, up to 300K, works the same, so I'll just use a 10k instead of the 220.
Actually yes that would be wise, especially with the CMOS version the 7555 (which is superior in many respects).
Schottky clamp diodes conduct first and protect better against latch-up. The standard '555 inputs are not
rated for min input voltage AFAICT.
