Hi All,
I am attempting to parse the data received from an absolute position encoder using RS485. I have attached a few relevant snippets from the datasheet as images. Note it is translated from another language, so it's not the most coherent.
I had purchased a USB to RS485 converted to monitor the data being received. Per the datasheet, I received a steady stream of HEX data in the format of:
AA BB 01 X1 X2 X3 X4 X5 X6 X7 X8 CS
In my project I am only concerned with the position of the absolute encoder, and per the datasheet this is obtained using X7+X8. I am able to see this clearly using a serial monitor debugger. The only error I was receiving at this point was a consistent CRC error.
Since I would like this to run on an MCU (Arduino Mega2560), I attempted to use the modbus protocol. Despite providing the correct Slave ID and albeit a random register address (wasn't clear which to choose from datasheet), I had continuously received the error "Invalid response function". Upon further research, it seems the standardised functions of Modbus do not match what the sensor is using.
I am new to using the RS485 standard, but it seems the only way to obtain this data is via Modbus. Any suggestions on how to properly receive this data would be greatly appreciated! And please let me know if I am missing any info, thanks.
#include<ModbusMaster.h>
#define MAX485_DE 3
#define MAX485_RE_NEG 2
ModbusMaster node;
void preTransmission()
digitalWrite(MAX485_RE_NEG, 1);
digitalWrite(MAX485_DE, 1);
void postTransmission()
digitalWrite(MAX485_RE_NEG, 0);
digitalWrite(MAX485_DE, 0);
pinMode(MAX485_RE_NEG, OUTPUT);
pinMode(MAX485_DE, OUTPUT);
// Init in receive mode
Serial1.begin(115200);
//slave ID 170
node.begin(0xAA, Serial1);
Serial.println("----------------------------");
Serial.println("Starting Modbus Transaction:");
node.preTransmission(preTransmission);
node.postTransmission(postTransmission);
static uint32_t i;
uint8_t j, result;
uint16_t data[10];
i++;
result = node.readHoldingRegisters(0x01,8);
Serial.println("");
if (result == node.ku8MBSuccess) {
Serial.print("Success, Received data: ");
for (j = 0; j < 2; j++) {
data[j] = node.getResponseBuffer(j);
Serial.print(data[j], HEX);
Serial.print(" ");
Serial.println("");
Serial.print("Failed, Response Code: ");
Serial.print(result, HEX);
Serial.println("");
delay(5000);
I also attempted a straight read from serial and print but this had resulted in random characters being printed such as reverse question marks.
const unsigned int MAX_MESSAGE_LENGTH = 12;
//Create a place to hold the incoming message
char message[MAX_MESSAGE_LENGTH];
unsigned int message_pos = 0;
//Check to see if anything is available in the serial receive buffer
while (Serial1.available() > 0)
//Read the next available byte in the serial receive buffer
char inByte = Serial1.read();
//Message coming in (check not terminating character) and guard for over message size
if ( inByte != '\n' && (message_pos < MAX_MESSAGE_LENGTH - 1) )
//Add the incoming byte to our message
message[message_pos] = inByte;
message_pos++;
//Full message received...
//Add null character to string
message[message_pos] = '\0';
for (int cnt = 0; cnt < strlen(message); cnt++)
Serial.print(message[cnt], HEX);
//Print the message (or do other things)
//Reset for the next message
message_pos = 0;
Datasheet Screenshots
https://ibb.co/Gs0N1Pv
https://ibb.co/Qr6Q6Nf
