Troubleshooting Self-Balancing Robot: Motor Control Issues with Arduino Uno and L298N Motor Driver
I am building a self balancing robot using Arduino Uno, mpu6050, l298n motor driver and BO DC gear motor.
I am facing a problem that my Arduino leaves control of the motors at high angles (10 to 30 degrees) or at high rate of change of angle.
Initially I provided power to the Arduino through the motor driver, but now I am giving them seperate power supply (7.4 volts each) then also the problem persists.
I printed the motor speed on the serial monitor too. When the motors are not connected to the motor driver then everything works well and the speed gets printed on the monitor.
But when I connect the motors then the problem arises again. I saw that when the problem arises then the serial monitor stops printing the speed and motor starts rotating at the speed last printed by the serial monitor. After that even if I tilt the robot in opposite direction or bring it back to its setpoint it doesn't stop and neither does the serial monitor print anything until I press the reset button.
Is there a problem with the motor driver?
Here's a video recording for reference:
Click Here
Here's the code below for reference:
#include <math.h>
#include <Wire.h>
int c = 0;
const int MPU = 0x68;
long accelX, accelY, accelZ;
float gForceX, gForceY, gForceZ;
float Gyro_Angle, Acc_Angle, Auto_Setpoint;
int Activated;
long gyroX, gyroY, gyroZ;
float rotX, rotY, rotZ;
float theta, phi;
unsigned long millisOld;
float dt;
float AccX, AccY, AccZ;
float GyroX, GyroY, GyroZ;
float AccErrorX, AccErrorY, AccErrorZ, GyroErrorX, GyroErrorY, GyroErrorZ;
float Temp_Error, PID_I, Setpoint, PID_Value, Last_D_Error, PID_D;
#define MOTOR1_PIN1 10
#define MOTOR1_PIN2 9
#define MOTOR1_en 11
#define MOTOR2_PIN1 6
#define MOTOR2_PIN2 7
#define MOTOR2_en 5
float Kp = 2;
float Kd = 1;
float Ki = 0.001;
float setpoint=0.00;
float rollActual;
float error=0;
float errorOld;
float errorChange;
float errorSlope=0;
float errorArea=0;
float PID_output;
float PID_max = 30;
float PID_min = -30;
float MotorSpeed;
  Wire.begin();
  setupMPU();
  calculate_IMU_error();
  pinMode(MOTOR1_PIN1, OUTPUT);
  pinMode(MOTOR1_PIN2, OUTPUT);
  pinMode(MOTOR1_en, OUTPUT);
  pinMode(MOTOR2_PIN1, OUTPUT);
  pinMode(MOTOR2_PIN2, OUTPUT);
  pinMode(MOTOR2_en, OUTPUT);
  Auto_Setpoint = 0;
  analogWrite(MOTOR1_en,0);
  analogWrite(MOTOR2_en,0);
  digitalWrite(MOTOR1_PIN1, LOW);
  digitalWrite(MOTOR1_PIN2, LOW);
  digitalWrite(MOTOR2_PIN1, LOW);
  digitalWrite(MOTOR2_PIN2, LOW);
  millisOld = millis();
  recordAccelRegisters();
  recordGyroRegisters();
  Acc_Angle = (atan(-1 * accelX / sqrt(pow(accelY, 2) + pow(accelZ, 2))) * 180 / PI) - AccErrorY;
  if (Activated == 0 && Acc_Angle > -0.5 && Acc_Angle < 0.5) {    //If the accelerometer angle is almost 0
    Gyro_Angle = Acc_Angle;                                       //Load the accelerometer angle in the Gyro_Angle variable
    Activated = 1;                                                //Set "Activated" variable and start PID control
   dt = (millis() - millisOld) / 1000.;
  Gyro_Angle += rotY * dt;
  //complimentary filter
  Gyro_Angle = 0.98 * Gyro_Angle + 0.02 * (Acc_Angle); //phi
  // pid control stats here...
  //First, we calculate the error between the real angle and the value taht we want, in this case would be 0º
  Temp_Error = Gyro_Angle - Auto_Setpoint - Setpoint;
  if (PID_Value > PID_max || PID_Value < PID_min) {
    Temp_Error += PID_Value * 0.015 ;
  //I value
  if(-10 < Temp_Error < 10){
    PID_I += Ki * (Temp_Error);                                                 //Calculate the "I" value
  if (PID_I > 400)PID_I = 400;                                              //We limit the "I" to the maximum output
  else if (PID_I < -400)PID_I = -400;
  //Calculate the PID_D output value
  PID_D = Kd * (Temp_Error - Last_D_Error)/dt;
  //Calculate the PID output value
  PID_Value = Kp * Temp_Error + PID_I + Kd * (Temp_Error - Last_D_Error);
  if (PID_Value > 400)PID_Value = 400;                                      //Limit the P+I to the maximum output
  else if (PID_Value < -400)PID_Value = -400;
  Last_D_Error = Temp_Error;                                                //Store the error for the next loop
  if (PID_Value < 6 && PID_Value > - 6)PID_Value = 0;                       //Dead-band where the robot is more or less balanced
  if (Gyro_Angle > 30 || Gyro_Angle < -30 || Activated == 0) {              //If the robot falls or the "Activated" is 0
    PID_Value = 0;                                                          //Set the PID output to 0 so the motors are stopped
    PID_I = 0;                                                              //Reset the I-controller memory
    Activated = 0;                                                          //Set the Activated variable to 0
    Auto_Setpoint = 0;                                                      //Reset the Auto_Setpoint variable
  //conversion to motor speed;
  MotorSpeed =  (abs(PID_Value)/PID_max)*255;
  if(MotorSpeed > 255)MotorSpeed=255;
  analogWrite(MOTOR1_en, MotorSpeed);
  analogWrite(MOTOR2_en, MotorSpeed);
  if(PID_Value >= 0.8){
    digitalWrite(MOTOR1_PIN1, HIGH);
    digitalWrite(MOTOR2_PIN1, HIGH);
    //Serial.println("forward");
  else if(PID_Value <= -0.8){
    digitalWrite(MOTOR1_PIN2, HIGH);
    digitalWrite(MOTOR2_PIN2, HIGH);
    //Serial.println("backward");
  else{
    //Serial.println("stop");
  Serial.println(MotorSpeed);
void setupMPU() {
  Wire.beginTransmission(0b1101000); //This is the I2C address of the MPU (b1101000/b1101001 for AC0 low/high datasheet sec. 9.2)
  Wire.write(0x6B); //Accessing the register 6B - Power Management (Sec. 4.28)
  Wire.write(0b00000000); //Setting SLEEP register to 0. (Required; see Note on p. 9)
  Wire.endTransmission();
  Wire.beginTransmission(0b1101000); //I2C address of the MPU
  Wire.write(0x1B); //Accessing the register 1B - Gyroscope Configuration (Sec. 4.4)
  Wire.write(0x00000000); //Setting the gyro to full scale +/- 250deg./s
  Wire.write(0x1C); //Accessing the register 1C - Acccelerometer Configuration (Sec. 4.5)
  Wire.write(0b00001000); //Setting the accel to +/- 4g
  //some filtering for the raw data
  Wire.write(0x1A);
  Wire.write(0x03);
void recordAccelRegisters() {
  Wire.write(0x3B); //Starting register for Accel Readings
  Wire.requestFrom(0b1101000, 6); //Request Accel Registers (3B - 40)
  while (Wire.available() < 6);
  accelX = Wire.read() << 8 | Wire.read(); //Store first two bytes into accelX
  accelY = Wire.read() << 8 | Wire.read(); //Store middle two bytes into accelY
  accelZ = Wire.read() << 8 | Wire.read(); //Store last two bytes into accelZ
  processAccelData();
void processAccelData() {
  gForceX = (accelX / 8192.0);
  gForceY = (accelY / 8192.0);
  gForceZ = (accelZ / 8192.0);
void recordGyroRegisters() {
  Wire.write(0x43); //Starting register for Gyro Readings
  Wire.requestFrom(0b1101000, 6); //Request Gyro Registers (43 - 48)
  gyroX = Wire.read() << 8 | Wire.read(); //Store first two bytes into accelX
  gyroY = Wire.read() << 8 | Wire.read(); //Store middle two bytes into accelY
  gyroZ = Wire.read() << 8 | Wire.read(); //Store last two bytes into accelZ
  processGyroData();
void processGyroData() {
  rotX = (gyroX / 131.0)-GyroErrorX; //subtracting GyroErrorX
  rotY = (gyroY / 131.0)-GyroErrorY;
  rotZ = (gyroZ/ 131.0)-GyroErrorZ;
void calculate_IMU_error() {
  AccErrorX = AccErrorY = 0;
  GyroErrorX = GyroErrorY = GyroErrorZ = 0;
  c = 0;
  while (c < 200) {
    Wire.beginTransmission(MPU);
    Wire.write(0x3B);
    Wire.endTransmission(false);
    Wire.requestFrom(MPU, 6, true);
    AccX = (Wire.read() << 8 | Wire.read()) / 8192.0 ;
    AccY = (Wire.read() << 8 | Wire.read()) / 8192.0 ;
    AccZ = (Wire.read() << 8 | Wire.read()) / 8192.0 ;
    // Sum all readings
    AccErrorX = AccErrorX + ((atan((AccY) / sqrt(pow((AccX), 2) + pow((AccZ), 2))) * 180 / PI));
    AccErrorY = AccErrorY + ((atan(-1 * (AccX) / sqrt(pow((AccY), 2) + pow((AccZ), 2))) * 180 / PI));
    c++;
  //Divide the sum by 200 to get the error value
  AccErrorX = AccErrorX / 200;
  AccErrorY = AccErrorY / 200;
  AccErrorZ = AccErrorZ / 200;
  c = 0;
  // Read gyro values 200 times
  while (c < 200) {
    Wire.write(0x43);
    GyroX = Wire.read() << 8 | Wire.read();
    GyroY = Wire.read() << 8 | Wire.read();
    GyroZ = Wire.read() << 8 | Wire.read();
    GyroErrorX = GyroErrorX + (GyroX / 131.0);
    GyroErrorY = GyroErrorY + (GyroY / 131.0);
    GyroErrorZ = GyroErrorZ + (GyroZ / 131.0);
    c++;
  GyroErrorX = GyroErrorX / 200;
  GyroErrorY = GyroErrorY / 200;
  GyroErrorZ = GyroErrorZ / 200;
show datasheet?
I think it is the way it is connected. You are losing 2.8 volts to the motor which is being burnt up as heat in the L298 driver. It is an old bipolar device which may be over 20 year old design. Pick a device with MOSFET outputs you will get a lot more power out of the motors. Posting links to technical information on each of the hardware devices helps us help you. I think there may be an error in your code around line 47 but since it was not posted with code tags I cannot be sure.
I have provided the code and a video of the robot going through the problem.
I have seen people use this motor driver in their self balancing Robot that's why I used this driver. But I just cannot figure out the problem and I am completely stuck.
I have watched your video. engine speed is not sufficient for balancing. anyway, can you watch the output value of the MPU when you make exactly the same movements as in the video?
Yes I am able to see the angle measured by mpu6050 and the motor speed which I am printing on the serial monitor.
But when the problem occurs then the serial monitor stops printing and motor starts rotating at the last provided speed. Upon pressing the reset button robot calibrates and starts printing the data again on the serial monitor till the problem repeats.
ok, make new sketch only to show axes in serial port, nothing else, and make same moves
Ok I will. In your opinion what could be the possible reason for this problem?
Earlier when I was providing the Arduino power through the motor driver's 5V pin then I thought that possible reason could be that motors are dropping the voltage at the 5V pin and Arduino is not able to get the constant 5V supply and because of that it is unable to control at greater angles or higher rate of change. So I seperated the power supply of both Arduino and motor driver. Both are now getting seperate 7.4 volts through the Lithium ion battery. But doing this didn't change anything.
did you find the mistake?
No the problem continues.
Hi, @abhishek_kanti
Can you please post some images of your project?
So we can see your component layout.
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
