I am very new to Arduino, usually a performing artist.
For a performance project, I had the idea to build a pair of shoes that appear to be walking across stage on their own.
The solution I am considering is as follows:
Two servos with a winch, each attached to one shoe. Then the Arduino would have to be programmed to activate the servos alternatingly one at a time, to pull the shoes a couple of centimeters.
Ideally, I would like to start/stop it wirelessly from a distance (5-10m)
My first thought is to use stepper motors, but that servo looks to be beefy enough. As far as the battery, you will need something powerful enough to operate the servos; the MCU (Nano) is trivial.
As far as the 'transceiver' goes, depending on the distance, Bluetooth may be out; Wi-Fi is a maybe. I would use ESP-NOW. That eliminates the Nano, but a SEEED Studio XIAU board is thumbnail-sized.
Hi, thanks for the reply!
well kinda, since the floor is black and the lines are black the lines should be hidden with stage lighting, so it's mostly to have the illusion to have them move by itself for a few seconds, and then I'll eventually play around with having something on the shoes itself so the tip maybe lifts up and down with each step, not sure yet.
I've also considered finding a way to have something at the shoes itself to move them but that all seems way too complicated to be worth the effort
Hi @heleneh. I would suggest two distinct mechanisms:
a mechanism that provides vertical motion, lifting each shoe alternately
a mechanism that provides horizontal motion, moving the shoes across the stage
The horizontal movement mechanism needs to be capable of travel over a more significant distance than the vertical movement mechanism.
For the vertical motion, you might look into a "cammed" approach, where each shoe is connected to a motor shaft at an offset by an arm. I think that could create a realistic walking motion. It would also be able to achieve the appropriate speed of movement, which I'm a bit doubtful about the winch motor's ability to provide.
For the horizontal mechanism, I would suggest a part that moves along a rail. I'm thinking of something like the solution you see here:
which utilizes a timing belt and aluminum extrusion. Of course you wouldn't have the vertical axis part for your project.
Those parts are commonly used by the 3D printer community, so are widely available for a relatively reasonable price (you can get the parts individually rather than as a kit like what is shown in that video). Your project probably requires a longer rail than what you could easily obtain the aluminum extrusion in a single piece. You could probably connect multiple pieces together, but you might be better off replacing it with something available from the hardware store or salvage, such as PVC pipe, conduit, or perhaps the rail for sliding closet doors. Or perhaps there is some accessible solution common in your line of work (someone like a stagehand might be able to advise you on that if you aren't aware of one yourself).
1. Get your Ardduino NANO. 2. Get your Servo Motor. 3. If you have not worked before with Arduino, then carry out Step-4; else, carry out Step-5.
4. Install IDE 2.3.10 in your PC. Connect NANO with PC. Open IDE. Check that NANO is recognized in the COM Port. From Examples of the IDE, open Blink sketch and upload it. Check that the onboard LED is blinking at 1 sec interval.
5. Now, connect Servo Motor with PC. Search net for information how to program a Servo Motor.
That sounds like a really creative project, and I think your idea should work in principle. An Arduino Nano, two servos with winches, a separate battery pack, and a wireless trigger are probably all you'll need for a first prototype. If you're new to Arduino, I'd recommend testing with just one shoe and one servo first so you can get a feel for the movement and power requirements before scaling up. The biggest challenge will likely be making the motion look natural rather than the programming itself, so expect to spend some time experimenting with the mechanics and timing. Overall, it seems like a very achievable project and a great way to learn Arduino while creating a unique stage effect.
Since you are describing an alternating movement, did you consider a crank shaft with two throws, 180 degrees apart. Operated by an electric motor. The cord from each shoe will wind around the crank pin on each crank. That will give alternating movement and advance each shoe as the cord winds. You can remote control the motor power.
I wonder if you can hide black then can you build an RC car into each shoe and maybe raise each step as it moves forward. Use soft tires and quiet motors and a bit of shuffle, toe drag to cover what noise is made. They could have leds if you want that you can change the colors with 16 million palette at high framerates if desired. Brightness on the shoe makes dark underneath very hard to see.
With 2 wheels up front and heel drag, it could turn. Undercarriage could be wrapped in fuzzy black cloth to hide and the shoe might be lifted whole and tilted with enough hardware and "millis based code"... you do want dancing shoes? Can do an old man shuffle but high steps and kicks would require rigging the stage where these shoes would be stand-alone capable, Arduino pun intended.
+1 to post #8. You really have a complex project in mind as your intro to Arduino!
At least consider a longish timescale and the following individual successive projects. Post for help when you run into problems during them.
Basic reading, installation and simple experiment with a Uno R3 or classic Nano.
Use the Arduino built in examples using servos. Both regular 180 and 360 ('winch') types.
See what they can do mechanically with whatever you can improvise.
Buy a few inexpensive pairs of 433 MHz transmitter (TX) and receiver (RX) modules; get those working so that the RX will toggle an LED at the distance you have in mind.
Develop a more detailed description of your objective. I could list many extra details you haven't specified. No point at this stage.
