i am using this amplifier as i connect probe to it directly goes to highest reading that is 4095 and even using ph offset screw didn't work
connected v+ to 3v3 of esp32
g to gnd
and po for input of data
Can you please post your code, using code tags?
Can we please have a circuit diagram?
An image of a hand drawn schematic will be fine, include ALL power supplies, component names and pin labels.
Can you please post a link to data/specs of the PH sensor?
Can you please tell us your electronics, programming, arduino, hardware experience?
Hi i have a same problem. Does your problem with ph sensor that alway show 4095 solved? Can you explain to me how to solve it because im doing my final years project and have a same problem.
Problems with electronics. The TLC4502 was faulty, its output hung up on the supply voltage, I replaced it with an LMC662. But it couldn't be calibrated either. The value of the resistance in the TLC4502 feedback circuit was 50k, it had to be reduced to 20k. The BNC connector contact was faulty, I had to cut it off and connect it by soldering. Everything else has been good... so far.
