FIrst of all I have no experience with arduino platform and limited knowledge in electronics.
I found a detail guide on how to build a cheap cnc hot wire cutter for college and I want to build it.
The guy who made it also provides a .hex and .bas file that I pressume goes intot he atmega8 controller. He listed the required piece as an Atmega8a-pu.
The problem is, I can't find one in Bucharest after searching for 2 months. The ones that I did find are:
Atmega8(L)-8Pu
Atmega8-16PU
From what I gatherer these are older models than the A variant, running at 8 and 16mhz respectively with more power consumption. Will the 16PU variant work? Can I power it and two other 5v stepper motors using only a usb to ttl adapter pl2303?
I attached the hex and bas files if they help and also the links to this project.
daskallu:
It's a very simple program that can be easily adapted to the Arduino. A direct translation would look like the code below. It would be good to change the direct port manipulation to calls to the Stepper library. It accepts characters from the serial port and, for inputs of 'A', 'B', 'C', or 'D', runs the X or Y stepper Forward or Backward about 20 steps (5 times 8 half-steps).
const int Wai = 3;
Serial.begin(19200);
DDRB |= 0x0F; // Set bits 0 through 3 to OUTPUT
DDRC |= 0x0F; // Set bits 0 through 3 to OUTPUT
int A = Serial.read(); // get ascii value from serial port
if (A == -1) // If nothing ready...
return;
if (A == 'A') {
for (int x = 0; x < 5; x++) {
PORTB = 1;
delay(Wai);
PORTB = 3;
delay(Wai);
PORTB = 2;
delay(Wai);
PORTB = 6;
delay(Wai);
PORTB = 4;
delay(Wai);
PORTB = 12;
delay(Wai);
PORTB = 8;
delay(Wai);
PORTB = 9;
delay(Wai);
PORTB = 0;
if (A == 'B') {
PORTB = 9;
delay(Wai);
PORTB = 8;
delay(Wai);
PORTB = 12;
delay(Wai);
PORTB = 4;
delay(Wai);
PORTB = 6;
delay(Wai);
PORTB = 2;
delay(Wai);
PORTB = 3;
delay(Wai);
PORTB = 1;
delay(Wai);
PORTB = 0;
if (A == 'C') {
PORTC = 1;
delay(Wai);
PORTC = 3;
delay(Wai);
PORTC = 2;
delay(Wai);
PORTC = 6;
delay(Wai);
PORTC = 4;
delay(Wai);
PORTC = 12;
delay(Wai);
PORTC = 8;
delay(Wai);
PORTC = 9;
delay(Wai);
PORTC = 0;
if (A == 'D') {
PORTC = 9;
delay(Wai);
PORTC = 8;
delay(Wai);
PORTC = 12;
delay(Wai);
PORTC = 4;
delay(Wai);
PORTC = 6;
delay(Wai);
PORTC = 2;
delay(Wai);
PORTC = 3;
delay(Wai);
PORTC = 1;
delay(Wai);
PORTC = 0;
