(I am using the Elegoo 5V 28BYJ-48 motor)
(I am also using the Stepper library)
So basically I am using a stepper motor to spin and I want to increase the speed to about 50 RPM-ish. I don't know if this is a motor problem or a code problem. If I change the myStepper.setSpeed() or stepsPerRevolution to a higher amount, the stepper motor driver module blinks red and the stepper motor does not move. I do not know what is the cause.
Here is the code (The code is not entirely mine, I found this and then edited it)
// Stepper - Version: Latest
#include <Stepper.h>
Stepper Motor Control - one revolution
This program drives a unipolar or bipolar stepper motor.
The motor is attached to digital pins 8 - 11 of the Arduino.
The motor should revolve one revolution in one direction, then
one revolution in the other direction.
Created 11 Mar. 2007
Modified 30 Nov. 2009
by Tom Igoe
const int stepsPerRevolution = 900; // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8, 10, 9, 11);
// set the speed at 60 rpm:
myStepper.setSpeed(45);
// initialize the serial port:
// step one revolution in one direction:
Serial.println("clockwise");
myStepper.step(stepsPerRevolution);
delay(10);
Top speed for a 28BYJ-48 is about 13 RPM, steps per revolution is about 2048.
by Tom Igoe
const int stepsPerRevolution = 2048; // change this to fit the number of steps per revolution
// for your motor
// set the speed at 12 rpm:
myStepper.setSpeed(12);
