Hello
I have TTGO Lora V1.6 with onboard sd card and i need any sd card example.
I tired a few example but sd card failed.
Please tell me which sample can i use for sd card?
Board:
Hello
Board:
First google result: GitHub - jonashoechst/ttgo-lora-sd: TTGO LoRa and SD card (working demo)
google "Arduino" + board + problem or requirement
I changed pins like that and mounted sd card
#define SD_CS 13
#define SD_SCK 14
#define SD_MOSI 15
#define SD_MISO 2
Sweet, good work.
Please post a working sketch here to help future users.
#include <Arduino.h>
#include <SPI.h>
#include <SD.h>
#include <RH_RF95.h>
#include <RHSoftwareSPI.h>
// SD SPI pins can be chosen freely, but cannot overlap with other ports!
#define SD_CS 13
#define SD_SCK 14
#define SD_MOSI 15
#define SD_MISO 2
#define LORA_FREQ 868.0
#define LOG_PATH "/lora_recv.log"
// The sd card can also use a virtual SPI bus
SPIClass sd_spi(HSPI);
// Use a virtual (software) SPI bus for the sx1278
RHSoftwareSPI sx1278_spi;
RH_RF95 rf95(LORA_CS, LORA_IRQ, sx1278_spi);
// Builtin LED
pinMode(LED_BUILTIN, OUTPUT);
// Serial output
// LoRa: Init
pinMode(LORA_RST, OUTPUT);
digitalWrite(LORA_RST, LOW);
delay(100);
digitalWrite(LORA_RST, HIGH);
// the pins for the virtual SPI explicitly to the internal connection
sx1278_spi.setPins(LORA_MISO, LORA_MOSI, LORA_SCK);
if (!rf95.init())
Serial.println("LoRa Radio: init failed.");
Serial.println("LoRa Radio: init OK!");
// LoRa: set frequency
if (!rf95.setFrequency(LORA_FREQ))
Serial.println("LoRa Radio: setFrequency failed.");
Serial.printf("LoRa Radio: freqency set to %f MHz\n", LORA_FREQ);
rf95.setModemConfig(RH_RF95::Bw125Cr45Sf128);
// LoRa: Set max (23 dbm) transmission power.
rf95.setTxPower(23, false);
// SD Card
sd_spi.begin(SD_SCK, SD_MISO, SD_MOSI, SD_CS);
if (!SD.begin(SD_CS, sd_spi))
Serial.println("SD Card: mounting failed.");
Serial.println("SD Card: mounted.");
uint8_t lora_buf[RH_RF95_MAX_MESSAGE_LEN];
uint8_t lora_len;
uint8_t receive_counter = 0;
// Blink LED
digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
lora_len = RH_RF95_MAX_MESSAGE_LEN;
if (rf95.recv(lora_buf, &lora_len)) {
receive_counter++;
Serial.printf("Received LoRa message #%i (%i bytes):\n%s\n", receive_counter, lora_len, lora_buf);
File test = SD.open(LOG_PATH, FILE_APPEND);
if (!test) {
Serial.println("SD Card: writing file failed.");
Serial.printf("SD Card: appending data to %s.\n", LOG_PATH);
test.write(lora_buf, lora_len);
test.printf("\n\n");
test.close();
delay(100);
platform.ini
[env:ttgo-lora32-v1]
platform = espressif32
board = ttgo-lora32-v1
;ttgo-lora32-v21
framework = arduino
monitor_speed = 115200
lib_deps =
RadioHead
;mbed-danjulio/RadioHead @ 0.0.0+sha.e69d086cb053
