TTGO micro-32 will not run code!
I am not sure where the best place to ask this question would be as the TTGO micro-32 has very little documentation. Anyway, I designed a custom PCB with the TTGO micro-32 microcontroller - supposedly a smaller version of the ESP32 - and it is programmed using the CP2102N. I am able to upload code to it from the Arduino IDE, but it will not run the code as far as I can tell. I can't get it to print anything in the Serial Monitor, so I have no idea what I need to do.
Here is the schematic for the whole thing:
Here are the settings I have selected in the tools menu:
Board: ESP32 Dev Module
Upload Speed: 115200
CPU Frequency: 240Hz (Wi-Fi/BT)
Flash Frequency: 80MHz
Flash Mode: QIO
Flash Size: 4MB
Partition Scheme: Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS)
Core Debug Level: None
PSRAM: Disabled
Port: COM 9
programmer: None
I would write a simple Blink program. I don't see an LED on the board so you will have to use a meter on a currently unused pin. It's where I always start with a new board.
That and check the voltage on every pin of the processor even the ground pins (using a reliable ground from the board. Verify each pins voltage makes sense to you.
Yep, i tried that earlier and it wasn't changing the state of the GPIO pin. It uploaded the code, but then just didn't do anything. I also checked the VIN and GND and everything seemed fine, so i don't know what im missing.
When you mention "custom board" I assume you mean a carrier for one of these:
When you were checking the state of an IO pin did you use the "Blink w/o delay" from the examples or did you add it into your current program? I would use the B w/o D minimal code for a test.
I've never used this device, does it need a special board support file(s)? Does your device have a bootloader installed (by the supplier?)?
I'm guessing because there is no "development board" (that I could easily find) you don't know if the issue is program, board support or hardware.
Have your read this post?
That's about all I've got that can be of any help. Please post the solution when you finally get it going :slight_smile:
Good Luck :slight_smile: (meant in a friendly way).
your posted schematic is pretty illegible , but I don't think I see the usual transistor-based flipflop for getting the modules into and out of "upload" mode...
Would you care to elaborate on this flip-flop circuit because i didn't know that was a thing.
The ESP32 "boot mode" requires manipulation of 2 or 3 pins (RESET + some GPIO pins that indicated "boot mode.") See Boot Mode Selection - ESP32 - — esptool.py latest documentation
To get the sort of auto-upload functionality that Arduino users are used to, I think (I'm not an ESP32 expert) usually accomplished by fiddling with the DTR and RTS pins, and a sort of set/reset flipflop circuit to make the states last long enough.
Here's an example. The fliplop is the part circled in orange in the lower left corner...
