Hi everyone
I'm currently working on a code where I'm receiving sensor data in the form of "FF A0" as a payload in TTN. I'm struggling to decode this payload back into its original value, which should represent soil moisture readings. Here's the full code I'm using in Arduino:
* Copyright (c) 2015 Thomas Telkamp and Matthijs Kooijman
* Copyright (c) 2018 Terry Moore, MCCI
* Permission is hereby granted, free of charge, to anyone
* obtaining a copy of this document and accompanying files,
* to do whatever they want with them without any restriction,
* including, but not limited to, copying, modification and redistribution.
* NO WARRANTY OF ANY KIND IS PROVIDED.
* This example sends a valid LoRaWAN packet with payload "Hello,
* world!", using frequency and encryption settings matching those of
* the The Things Network. It's pre-configured for the Adafruit
* Feather M0 LoRa.
* This uses OTAA (Over-the-air activation), where where a DevEUI and
* application key is configured, which are used in an over-the-air
* activation procedure where a DevAddr and session keys are
* assigned/generated for use with all further communication.
* Note: LoRaWAN per sub-band duty-cycle limitation is enforced (1% in
* g1, 0.1% in g2), but not the TTN fair usage policy (which is probably
* violated by this sketch when left running for longer)!
* To use this sketch, first register your application and device with
* the things network, to set or generate an AppEUI, DevEUI and AppKey.
* Multiple devices can use the same AppEUI, but each device has its own
* DevEUI and AppKey.
* Do not forget to define the radio type correctly in
* arduino-lmic/project_config/lmic_project_config.h or from your BOARDS.txt.
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
// This EUI must be in little-endian format, so least-significant-byte
// first. When copying an EUI from ttnctl output, this means to reverse
// the bytes. For TTN issued EUIs the last bytes should be 0xD5, 0xB3,
// 0x70.
static const u1_t PROGMEM APPEUI[8]= { 0x55, 0x66, 0x55, 0x44, 0x44, 0x11, 0x33, 0x22 };
void os_getArtEui (u1_t* buf) { memcpy_P(buf, APPEUI, 8);}
// This should also be in little endian format, see above.
static const u1_t PROGMEM DEVEUI[8]= { 0x68, 0x22, 0x00, 0xD8, 0x7E, 0xD5, 0xB3, 0x70 };
void os_getDevEui (u1_t* buf) { memcpy_P(buf, DEVEUI, 8);}
// This key should be in big endian format (or, since it is not really a
// number but a block of memory, endianness does not really apply). In
// practice, a key taken from the TTN console can be copied as-is.
static const u1_t PROGMEM APPKEY[16] = { 0x07, 0xF2, 0x45, 0xE6, 0x10, 0x28, 0xCC, 0x90, 0x78, 0x4D, 0xA3, 0xEA, 0x4A, 0x35, 0xA0, 0x92 };
void os_getDevKey (u1_t* buf) { memcpy_P(buf, APPKEY, 16);}
static uint8_t mydata[] = "Hello, world!";
static osjob_t sendjob;
// Schedule TX every this many seconds (might become longer due to duty
// cycle limitations).
const unsigned TX_INTERVAL = 10;
// Pin mapping
//# error "Unknown target"
const lmic_pinmap lmic_pins = {
.nss = 10,
.rxtx = LMIC_UNUSED_PIN,
.rst = 9,
.dio = {3,4,5},
.rxtx_rx_active = 0,
.rssi_cal = 0, // LBT cal for in dB
.spi_freq = 1000000
int sensor_pin = A0;
int output_value;
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch(ev) {
case EV_SCAN_TIMEOUT:
Serial.println(F("EV_SCAN_TIMEOUT"));
case EV_BEACON_FOUND:
Serial.println(F("EV_BEACON_FOUND"));
case EV_BEACON_MISSED:
Serial.println(F("EV_BEACON_MISSED"));
case EV_BEACON_TRACKED:
Serial.println(F("EV_BEACON_TRACKED"));
case EV_JOINING:
Serial.println(F("EV_JOINING"));
case EV_JOINED:
Serial.println(F("EV_JOINED"));
u4_t netid = 0;
devaddr_t devaddr = 0;
u1_t nwkKey[16];
u1_t artKey[16];
LMIC_getSessionKeys(&netid, &devaddr, nwkKey, artKey);
Serial.print("netid: ");
Serial.println(netid, DEC);
Serial.print("devaddr: ");
Serial.println(devaddr, HEX);
Serial.print("artKey: ");
for (int i=0; i<sizeof(artKey); ++i) {
if (i != 0)
Serial.print("-");
Serial.print(artKey[i], HEX);
Serial.println("");
Serial.print("nwkKey: ");
for (int i=0; i<sizeof(nwkKey); ++i) {
if (i != 0)
Serial.print("-");
Serial.print(nwkKey[i], HEX);
Serial.println("");
// Disable link check validation (automatically enabled
// during join, but because slow data rates change max TX
// size, we don't use it in this example.
LMIC_setLinkCheckMode(0);
|| This event is defined but not used in the code. No
|| point in wasting codespace on it.
|| case EV_RFU1:
|| Serial.println(F("EV_RFU1"));
|| break;
case EV_JOIN_FAILED:
Serial.println(F("EV_JOIN_FAILED"));
case EV_REJOIN_FAILED:
Serial.println(F("EV_REJOIN_FAILED"));
case EV_TXCOMPLETE:
Serial.println(F("EV_TXCOMPLETE (includes waiting for RX windows)"));
if (LMIC.txrxFlags & TXRX_ACK)
Serial.println(F("Received ack"));
if (LMIC.dataLen) {
Serial.print(F("Received "));
Serial.print(LMIC.dataLen);
Serial.println(F(" bytes of payload"));
Serial.print("Port: ");
Serial.println(LMIC.frame[(LMIC.dataBeg-1)]);
Serial.print("Data: ");
// char rec_data = (LMIC.frame + LMIC.dataBeg);
for (int i=0; i< LMIC.dataLen; ++i) {
if (i != 0)
Serial.print(",");
Serial.print(LMIC.frame[LMIC.dataBeg+i], HEX);
// Schedule next transmission
os_setTimedCallback(&sendjob, os_getTime()+sec2osticks(TX_INTERVAL), do_send);
case EV_LOST_TSYNC:
Serial.println(F("EV_LOST_TSYNC"));
case EV_RESET:
Serial.println(F("EV_RESET"));
case EV_RXCOMPLETE:
// data received in ping slot
Serial.println(F("EV_RXCOMPLETE"));
case EV_LINK_DEAD:
Serial.println(F("EV_LINK_DEAD"));
case EV_LINK_ALIVE:
Serial.println(F("EV_LINK_ALIVE"));
|| case EV_SCAN_FOUND:
|| Serial.println(F("EV_SCAN_FOUND"));
|| break;
case EV_TXSTART:
Serial.println(F("EV_TXSTART"));
default:
Serial.print(F("Unknown event: "));
Serial.println((unsigned) ev);
void do_send(osjob_t* j){
// Check if there is not a current TX/RX job running
if (LMIC.opmode & OP_TXRXPEND) {
Serial.println(F("OP_TXRXPEND, not sending"));
output_value = analogRead(sensor_pin);
uint16_t output_value1 = map(output_value,693,350,0,100);
byte payload[2];
payload[0] = highByte(output_value1);
payload[1] = lowByte(output_value1);
// Prepare upstream data transmission at the next possible time.
LMIC_setTxData2(3, (xref2u1_t)(payload), sizeof(payload), 0);
Serial.println(F("Packet queued"));
// Next TX is scheduled after TX_COMPLETE event.
delay(5000);
while (! Serial)
Serial.println(F("Starting"));
#ifdef VCC_ENABLE
// For Pinoccio Scout boards
pinMode(VCC_ENABLE, OUTPUT);
digitalWrite(VCC_ENABLE, HIGH);
#endif
// LMIC init
os_init();
// Reset the MAC state. Session and pending data transfers will be discarded.
LMIC_reset();
LMIC_setClockError(MAX_CLOCK_ERROR * 1 / 100);
LMIC_setDrTxpow(DR_SF7,14);
// Start job (sending automatically starts OTAA too)
do_send(&sendjob);
os_runloop_once();
Here's the formatter code I'm using in TTN:
function Decoder(bytes, port) {
var decoded = {};
// soil moisture
rawSoilMoisture = bytes[0] + bytes[1] * 256;
decoded.soilMoisture = sflt162f(rawSoilMoisture) * 100;
return decoded;
function sflt162f(rawSflt16)
rawSflt16 &= 0xFFFF;
// special case minus zero:
if (rawSflt16 == 0x8000)
return -0.0;
// extract the sign.
var sSign = ((rawSflt16 & 0x8000) != 0) ? -1 : 1;
// extract the exponent
var exp1 = (rawSflt16 >> 11) & 0xF;
// extract the "mantissa" (the fractional part)
var mant1 = (rawSflt16 & 0x7FF) / 2048.0;
var f_unscaled = sSign * mant1 * Math.pow(2, exp1 - 15);
return f_unscaled;
