hi,
this is my first attempt with arduino and I'm having one problem, hope you can help.
I have 4 relays controlled by a bluetooth app.
Relays 3 and 4 are working fine, but not relays 1 e 2.
when the app sends the command for relays 1 or 2 they will turn on for about 25min, no problem here.
But i also want them to turn on/off at a specific time, 3 times a day.
And here is the problem, it only works on the day i upload the code, the next day it doesn't work any more.
I have connected the rtc to another arduino and the time is correct.
Can any one help, please?
#include <Wire.h>
#include <RTClib.h>
RTC_DS1307 rtc;
#define LED_PIN1 4
#define LED_PIN2 5
#define LED_PIN3 6
#define LED_PIN4 7
#define LED_PIN5 8
#define LED_PIN6 9
#define LED_PIN7 10
#define LED_PIN8 11
const int OnHour = 7;
const int OnMin = 0;
const int OffHour = 8;
const int OffMin = 0;
const int OnHour1 = 13;
const int OnMin1 = 0;
const int OffHour1 = 14;
const int OffMin1 = 0;
const int OnHour2 = 19;
const int OnMin2 = 0;
const int OffHour2 = 20;
const int OffMin2 = 0;
int firstSensor = 0; // first analog sensor
int secondSensor = 0; // second analog sensor
int thirdSensor = 0; // digital sensor
int inByte = 0; // incoming serial byte
boolean status_unlock;
boolean status_bluetooth;
// temporização
long interval = 1000; // interval at which to blink (milliseconds)
long previousMillis = 0; // will store last time LED was updat
int minite,sec;
unsigned long startTime;
unsigned long currentTime;
unsigned long period = 20*60*1000UL; //adjust to change period
unsigned long startTime2;
unsigned long period2 = 20*60*1000UL; //adjust to change period
const byte inputPin = A1;
const byte ledPin = 4;
boolean timing = false;
boolean timing2 = false;
// start serial port at 9600 bps:
//pinMode(2, INPUT); // digital sensor is on digital pin 2
//establishContact(); // send a byte to establish contact until receiver responds
Wire.begin();
rtc.begin();
pinMode(LED_PIN1, OUTPUT);
pinMode(LED_PIN2, OUTPUT);
pinMode(LED_PIN3, OUTPUT);
pinMode(LED_PIN4, OUTPUT);
pinMode(LED_PIN5, OUTPUT);
pinMode(LED_PIN6, OUTPUT);
pinMode(LED_PIN7, OUTPUT);
pinMode(LED_PIN8, OUTPUT);
digitalWrite(LED_PIN1, HIGH); // switch on LED
digitalWrite(LED_PIN2, HIGH); // switch on LED
digitalWrite(LED_PIN3, HIGH); // switch on LED
digitalWrite(LED_PIN4, HIGH); // switch on LED
digitalWrite(LED_PIN5, HIGH); // switch on LED
digitalWrite(LED_PIN6, HIGH); // switch on LED
digitalWrite(LED_PIN7, HIGH); // switch on LED
digitalWrite(LED_PIN8, HIGH); // switch on LED
status_bluetooth = true;
status_unlock = false;
sec = 0;
currentTime = millis();
if (Serial.available() > 0) {
inByte = Serial.read(); // get incoming byte:
if(inByte == 'A'){
Serial.print('A'); // send a char
digitalWrite(LED_PIN1, LOW); // switch on LED
inByte = 0;
startTime = millis();
timing = true;
if (currentTime - startTime >= period)
digitalWrite(LED_PIN1, HIGH); //turn off the LED
//if (Serial.available() > 0) {
if(inByte == 'B'){
digitalWrite(LED_PIN2, LOW); // switch on LED
Serial.print('B'); // send a char
inByte = 0;
startTime2 = millis();
timing2 = true;
if (currentTime - startTime2 >= period2)
digitalWrite(LED_PIN2, HIGH); //turn off the LED
if(inByte == 'C'){
digitalWrite(LED_PIN3, LOW); // switch on LED
Serial.print('C'); // send a char
inByte = 0;
if(inByte == 'c'){
Serial.print('c'); // send a char
inByte = 0;
if(inByte == 'D'){
digitalWrite(LED_PIN4, LOW); // switch on LED
Serial.print('D'); // send a char
inByte = 0;
if(inByte == 'd'){
Serial.print('d'); // send a char
inByte = 0;
if(inByte == 'a'){
Serial.print('a'); // send a char
inByte = 0;
if(inByte == 'b'){
Serial.print('b'); // send a char
inByte = 0;
DateTime now = rtc.now();
if(now.hour() == OnHour && now.minute() == OnMin){
else if(now.hour() == OffHour && now.minute() == OffMin){
if(now.hour() == OnHour1 && now.minute() == OnMin1){
else if(now.hour() == OffHour1 && now.minute() == OffMin1){
if(now.hour() == OnHour2 && now.minute() == OnMin2){
else if(now.hour() == OffHour2 && now.minute() == OffMin2){
