I need to route two Tx lines, from two MCU's, to one Rx input on a third MCU.
Normally I use an opto-isolator when connecting Tx to Rx. Now I want to add another Tx line (Tx-B) directly to the Rx input. The two Tx lines will never transmit data simultaneously. Would the attached schematic work?
The TX signal is a solid and strong 0V or 5V, or 3.3V (that depends on the device that outputs the TX).
You can combine them by converting them both to a open collector signal and create a pullup signal. Therefor you must use resistors or optocouplers or perhaps diodes or a logic gate or a transistor to combine them.
Peter_n:
That optocoupler inverts the TX-A signal.
nope. When the Cathode of the LED (Tx line) is high the NPN transistor is closed, so the level on Rx is also high, and vise-verse Tx-A low = Rx low.
So as far as I see it, it's either the NPN in the Opto-coupler than can pull Rx low or the Tx-B line, i.e. when Tx-B is Logic 1 it conducts from Vcc through R1 and R3 to ground, thereby Rx see's a low which is Logic 1 (UART is inverted logic). Unless I'm missing something.
p.s. perhaps it would be good idea to add a diode between R3 and Tx-B: R3 - anode - cathode - Tx-B, so that when the NPN is open, Tx-B will not source power to ground, but I'm not sure, maybe this is not a problem and a diode is not necessary.
OK, it took me a while to verify that the idle state of MIDI is in fact, OFF.
So you have R1 of about 4k7 to pull the Rx input HIGH. You want a diode instead where you illustrate R3, cathode to the Tx-B so that it definitively pulls the line LOW when Tx-B goes LOW.
I am not sure where you got R2 from, it presumably sets a sensitivity threshold for the opto-coupler.
Paul__B:
hmm, I guess I don't understand what idle state means. I thought it means when there is no data being transmitted, which afaik is when Tx is constantly high, i.e. after a stop and before a start bit.
Good, so I had the right idea.
R2 is there to improve the fall time of the photo transistor. MIDI devices usually use 6n138/6n139 opto-couplers, the 4n25/4n35 are slower and don't produce very good wave forms at MIDI baud 31250.
So I guess multiple Tx lines can be connected to an Rx input through diodes, as long as only one Tx line is active at any given time?
I think there are some other options available to you for the arduino. I'm MIDI challenged so I won't be any help to you but there are many people who have done stuff with MIDI who might have some advice for you.
I would change your post title in your original post to decribe your MIDI application to attract the MIDI experienced members.
