ultrasonic sensor 3pins vs 4pins ?
hello guys,
i have an ultrasonic sensor which i bough last year for 20$ with 3 pins: + OUT -
and now while checking some tutorials on youtube, i see that all the sensor used have 4 pins, echo and trigger, and their price is around 2.7$
here is the link for the 3 pins sensor i got : http://www.ekt2.com/products/productdetails?ProductId=da1053bd-dfce-4f16-8fb1-7dba240991fe
and this for the 4 pins which i will buy later this day but it will cause a problem with arduino pins because i will be using 4 of these which means 8 pins, and i will run out of pins with L293D and other chips http://www.ekt2.com/products/productdetails?ProductId=2ec67a91-978e-4a2f-8524-e672539d9644
so i need please to know what is the difference and in its programming ?
Ping))) (sp?) sensors have only three pins, don't they?
AWOL:
well yea i was searching and i found that its name is Ping sensor
but is there any difference between the ping and ultrasonic i mean other than the range, any new characteristic that can be found in the ping sensor that is not in the ultrasonic ?
3 or 4 pins sensor are the same except that 3 pins sensor share Trig and Echo signals on the same pin.
68tjs:
yes, the advantage of 3 pin is that you can use many sensor it's won't consume as many as when you have 4 pins, but problem is it's expensive 16$ according to the 4 pins which is just 2.7$
In France we say " On ne peut pas avoir le beurre et l'argent du beurre "
Approximative translation : you can not have simultaneously the butter and the money to buy the butter.
The 3 pins model is new so it is expensive.
Wait a few months or a few weeks and it will cost less.
68tjs:
I think the equivalent English aphorism is "You can't have your cake and eat it", which is also clearly nonsense.
68tjs:
hahaha no i don't think so, maybe a little bit less but not way less, last year i got it for 20$, this year it's 16 :smiley: not bad :smiley:
