Ultrasonic sensor accuracy
For my project I am using five ultrasonic sensors at a distance of 35cm each, to monitor a users walk, each sensor is only supposed to take two readings for the users two legs, as of right now the sensors are picking up multiple readings. I have narrowed the sensors beam width by putting a 2.5cm tube on the receiver sensors it worked on a singular sensor but when put on the full device multiple readings are picked up again.
so I have two questions
Does anyone have any suggestions on how to optimise the sensors so they only pick up two readings each?
Is there a way to turn each sensor off after it has picked up two readings? turning them all back on and doing it two more times?
The code i am currently using (it works)
#include "SR04.h"
#define TRIG_PIN 12
#define ECHO_PIN 11
//SR04 sr04 = SR04(ECHO_PIN,TRIG_PIN);
SR04 sensor1 = SR04(11,12);
SR04 sensor2 = SR04(8,9);
SR04 sensor3 = SR04(6,7);
SR04 sensor4 = SR04(5,4);
SR04 sensor5 = SR04(3,2);
long a;
long b;
long c;
long d;
long e;
  Serial.println("Hello World");
   a=sensor1.Distance();
   b=sensor2.Distance();
   c=sensor3.Distance();
   d=sensor4.Distance();
   e=sensor5.Distance();
    Serial.print(millis());
    Serial.print(", ");
   //Serial.print("Sensor 1 ");
   Serial.print(a);
   Serial.print(", ");
   //Serial.print("cm  ");
   //Serial.print("Sensor 2 ");
   Serial.print(b);
   Serial.print(", ");
   //Serial.print("Sensor 3 ");
   Serial.print(c);
   Serial.print(", ");
   //Serial.println("cm");
   //Serial.print("Sensor 4 ");
   Serial.print(d);
   Serial.print(", ");
   //Serial.print("Sensor 5 ");
   Serial.print(e);
   Serial.println(", ");
   //delay(1000);
Give echoes time to die down, don't try to take readings of different sensors in too quick succession. 10-100 ms is usually what's needed, depending on the environment, how echoe-y it is.
Remember, each time you command the transmitter, it send 8 pulses and then waits for the first echo return. The remaining sound pulses are still out there!
Paul
