Unable to connect Sim7600x 4g hat to Arduino MEGA 2560
I have a Waveshare Sim7600X 4G Hat with the Sim7600A-H on it and I am trying to use it with an Arduino Mega 2560 (I think it's an off brand one, the one that Im using is pictured below) via UART. I have tried both this
and this
(Sorry I am a new user and it would not let me post with two images. config 2 is the same as the first however instead of connecting to the side header tx and rx I am connecting to the Pi header, the ground wire stays where it is, also imaged is the 4g hat with a Sim7600G-H, mine is the same board just with a Sim7600A-H)
wire setups, I have kept the small yellow jumpers on segment B (where they are in the images) as in the documentation this one seemed to simply forward the uart to the pi header pins. I have also tried simply removing these two jumpers in the first configuration.
Using an oscilloscope I have been able to see that the arduino is Txing what I assume is the correct message (at the very least it is txing) but I am unable to see anything coming back, I think something is coming back though as it is returning a backwards question mark sometimes, idk it is very odd, here is a picture of what Ive been getting back
(1 media thing again, here is the output in text)
15:37:58.676 -> Starting up...
15:37:58.777 -> AT Command:
15:37:58.777 -> AT
15:38:03.786 ->
15:38:03.886 -> AT Command:
15:38:03.886 -> AT
15:38:08.855 ->
15:38:09.972 -> AT Command:
15:38:09.972 -> AT
15:38:10.005 -> resp: ⸮
15:38:14.953 ->
15:38:16.077 -> AT Command:
15:38:16.077 -> AT
15:38:16.077 -> resp: ⸮
15:38:16.111 -> resp: ⸮
15:38:21.054 ->
15:38:22.164 -> AT Command:
15:38:22.198 -> AT
15:38:22.198 -> resp: ⸮
15:38:27.167 ->
15:38:28.284 -> AT Command:
15:38:28.284 -> AT
15:38:33.261 ->
for code I have been testing with 2 things the first is Ive been using a library Waveshare made and I have edited as shown below.
Header for Library
*  @filename   :   Waveshare_SIM7600.h
*  @brief      :   Implements for sim7600 library
*  @author     :   Kaloha from Waveshare
*  Copyright (C) Waveshare     April 27 2018
*  http://www.waveshare.com / http://www.waveshare.net
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documnetation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to  whom the Software is
* furished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS OR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
* OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
* THE SOFTWARE.
#ifndef Waveshare_sim7x00_h
#define Waveshare_sim7x00_h
#include <stdlib.h>
#if ARDUINO >= 100
  #include <Arduino.h>
#else
  #include <wiring.h>
#endif
//#define unsigned int uint8_t
/* Sim7x00 Class */
class Sim7x00 {
public:
  // Pin definition
  const static int powerkey = 2;
  int userkey;
  Sim7x00();
  ~Sim7x00();
  // SIM query
  void PowerOn();
  // Phone calls
  //void PhoneCall(const char* PhoneNumber);
  // SMS sending and receiving message
  bool SendingShortMessage(const char* PhoneNumber,const char* Message);
  bool ReceivingShortMessage();
  // Other functions.
  uint8_t sendATcommand(const char* ATcommand, const char* expected_answer, unsigned int timeout);
  //char sendATcommand2(const char* ATcommand, const char* expected_answer1, const char* expected_answer2, unsigned int timeout);
extern Sim7x00 sim7600;
#endif
Library File
*  @filename   :   Waveshare_SIM7600.cpp
*  http://www.waveshare.com  http://www.waveshare.net
* THE SOFTWARE.
#include "Waveshare_SIM7600.h"
Sim7x00::Sim7x00(){
Sim7x00::~Sim7x00(){
/**************************Power on Sim7x00**************************/
void Sim7x00::PowerOn(){
   uint8_t answer = 0;
  Serial1.begin(9600);
  Serial.println("Starting up...");
  // checks if the module is started
  answer = sendATcommand("AT", "OK", 5000);
  if (answer == 0)
    //Serial.print("Starting up...\n");
    //pinMode(PowerKey, OUTPUT);
    // power on pulse
    //digitalWrite(PowerKey, HIGH);
    //delay(500);
    //digitalWrite(PowerKey, LOW);
    // waits for an answer from the module
    while (answer == 0) {     // Send AT every two seconds and wait for the answer
  delay(5000);
  while ((sendATcommand("AT+CREG?", "+CREG: 0,1", 500) || sendATcommand("AT+CREG?", "+CREG: 0,5", 500)) == 0)
/**************************SMS sending and receiving message **************************/
//SMS sending short message
bool Sim7x00::SendingShortMessage(const char* PhoneNumber,const char* Message){
  uint8_t answer = 0;
  char aux_string[30];
  //Serial.print("Setting SMS mode...\n");
  sendATcommand("AT+CMGF=1", "OK", 1000);    // sets the SMS mode to text
  //Serial.print("Sending Short Message\n");
  sprintf(aux_string,"AT+CMGS=\"%s\"", PhoneNumber);
  answer = sendATcommand(aux_string, ">", 3000);    // send the SMS number
  if (answer == 1)
      Serial.println(Message);
      Serial.write(0x1A);
      answer = sendATcommand("", "OK", 20000);
      if (answer == 1)
          //Serial.print("Sent successfully \n");
          return true;
          //Serial.print("error \n");
          return false;
 //     Serial.print(answer);
      //Serial.print(" error.\n");
      return false;
//SMS receiving short message
bool Sim7x00::ReceivingShortMessage(){
  uint8_t answer = 0;
  int i = 0;
  char RecMessage[200];
  sendATcommand("AT+CPMS=\"SM\",\"SM\",\"SM\"", "OK", 1000);    // selects the memory
    answer = sendATcommand("AT+CMGR=1", "+CMGR:", 2000);    // reads the first SMS
  if (answer == 1)
        answer = 0;
        while(Serial.available() == 0);
        // this loop reads the data of the SMS
        do{
            // if there are data in the UART input buffer, reads it and checks for the asnwer
            if(Serial.available() > 0){
                RecMessage[i] = Serial.read();
                i++;
                // check if the desired answer (OK) is in the response of the module
                if (strstr(RecMessage, "OK") != NULL)
                    answer = 1;
        }while(answer == 0);    // Waits for the asnwer with time out
 //       RecMessage[i] = '\0';
        Serial.print(RecMessage);
        Serial.print("\n");
    return false;
  return true;
/**************************Other functions**************************/
uint8_t Sim7x00::sendATcommand(const char* ATcommand, const char* expected_answer, unsigned int timeout) {
    uint8_t x=0,  answer=0;
    char response[100];
    unsigned long previous;
    memset(response, '\0', 100);    // Initialize the string
    delay(100);
    while( Serial1.available() > 0) Serial1.read();    // Clean the input buffer
    Serial1.println(ATcommand);    // Send the AT command
    Serial.println("AT Command:");
    Serial.println(ATcommand);
    x = 0;
    previous = millis();
    // this loop waits for the answer
    do{
        if(Serial1.available() > 0){
            response[x] = Serial1.read();
            Serial.print("resp: ");
            Serial.println(response[x]);
            x++;
            // check if the desired answer  is in the response of the module
            if (strstr(response, expected_answer) != NULL)
                answer = 1;
    }while((answer == 0) && ((millis() - previous) < timeout));
    Serial.print("\n");
    return answer;
Sim7x00 sim7600 = Sim7x00();
Arduino Code
*  @filename   :   SMS.cpp
*  @brief      :   SIM7600CE 4G HAT demo
* THE SOFTWARE.
char phone_number[] = "**********";      //********** change it to the phone number you want to call
char text_message[] = "test";      //
  sim7600.PowerOn();
  Serial.println("made it");
  //printf("Sending Short Message Test:\n");
  //sim7600.SendingShortMessage(phone_number, text_message);
  //printf("Message sent, check phone");
I have also been testing with a more simple file that might not work I was just going for something that I thought would be the simplest possible setup, that code is below.
  if (Serial.available()) {
    Serial1.print(Serial.read());
    Serial.print(Serial.read());
  if(Serial1.available()) {
again though like I said this may be dumb and not useful for testing I dont know.
Please if anyone has had any experience with this hardware or something like it I need help, I do not know what I am doing wrong. If you need anymore information about the hardware or software I am 100% willing and able to provide.
Thank you <3
How are you powering the SIM7600 ?
Try using a different baud rate 115200 is often the default.
Also - the following is wrong...
I am powering the sim7600 with the micro usb to computer, I also have sent 3.3v to the pin on the yellow header (and connected ground) using an analog discovery 2. I have tried both 115200 and 9600, and before I did each I used putty and the command "at+ipr=(rate)" to set the sim's baud rate. I have also run tests with it set to 0 with sets the sim7600 to auto baud. also yeah Im dumb I edited the code. I have the second serial print in the first if though because I wanted it to log what I sent on the serial monitor as it wasn't doing that manually, is this a setting I need to turn on? thank you so much for your reply
I haven't used that Hat before, so not sure about the headers.
When you use putty do you get valid responses from the 7600 ?
When you send AT+IPR? and AT+IPREX? what do you get?
yes when I use putty I can use at commands to do everything I want to do, I am not at my desk rn so I cant test, when Ive done the at+ipr= something it returns ok
Ok... that's something.
If you can confirm what AT+IPR? and AT+IPREX? this will at least confirm what it thinks the baud rate is. Some modules don't support auto baud.
IPREX keeps it's value after power loss.
