Hi all,
I know there are hundreds of similar posts but I have probably read them all... so I could definitely use some help.
I am trying to program an Arduino Pro Mini 3.3V - 8MHz using my Arduino UNO as an ISP.
I can successfully upload the ArduinoISP sketch, the "heartbeat" LED (pin 9) comes up.
avrdude however can't seem to connect, with this command line
avrdude -p atmega328p -D -b 19200 -P COM7 -c arduino -v -v -v
I get this error (full output below):
avrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
I have tried
- 9600 (lowest I've read about)
- 19200 (the default in ArduinoISP sketch)
- 56600 (found in boards.txt for the pro mini 3.3v)
- 115200 (next option in ArduinoISP sketch)
I triple checked my connections:
- 11/12/13 connected to 11/12/13
- UNO 10 connected to Pro Mini Rst
- Pro Mini has its own 3.3V Vcc supply (led was very dim trying to feed from the UNO)
- All the grounds are connected
- 10mF capacitor between the UNO's GND and Reset pins
When I run avrdude the "programming" LED (pin 7) comes up briefly once, and that's all.
I am really out of ideas, so any suggestion would be really welcome!
Thanks,
Franck
avrdude: Version 5.10, compiled on Jan 19 2010 at 10:45:23
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "D:\WinAVR-20100110\bin\avrdude.conf"
Using Port : COM7
Using Programmer : arduino
Overriding Baud Rate : 19200
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 5 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
