I am attempting to make a MIDI Footcontroller that sends a Midi Note and possibly a Program Change with the push of a button. Right now I am just trying to get a Program change to transmit and it is sending a midi note. I feel like Ive done a lot of research and tried several things but nothing will work.
Do you see any issues in my Code? I do not have any comments as I am just in prototype mode. LOL
sendControlChange does not send a Program Change. Which do you want?
If you want Program Change the function has two arguments:
sendProgramChange(byte ProgramNumber,byte Channel)
I have tried it with ProgramChange also and used only two arguments with that.
When you say:
"sendProgramChange(byte ProgramNumber,byte Channel)" Does the "byte" have to be in the code? Sorry for the newbie questions.
This morning I tried this exact code:
sendProgramChange(60, 1)
When I open up ableton and press the button, It sends a C3 note on channel 1, Which would be note 60. Not sure why its not recognizing the sendProgramChange. I am using the MIDI library 4.2.
'byte' just tells you what type of argument the function expects and should not be included in your code when you call the function.
You also have a problem that while the button is LOW, you keep sending the Program Change code as fast as possible. This might confuse whatever is at the other end.
Try this for now:
if (button2 == LOW) {
MIDI.sendProgramChange(60, 1);
I figured out where I messed up. I didn't use the MIDI.begin(1). When I added this, everything works great now. Thanks for the help. Hope this might help someone else.
