There are several other posts with similar issues, but I haven't found a solution.
I have a Nano 33 IoT that seems to be functional I just can't get it setup with IoT Cloud.
Whenever I try to add it as a device, it errors out:
I am running:
MacOS 12.0 Beta (21A5552a)
Arduino Create Agent 1.2.5-a477c19
The Arduino appears to be working. The "Blink" example program works as expected.
Hi!
Not sure if that is the problem, but IoT Cloud uses to check the version of the u-Blox NINA firmware on the board before allowing it to conect.
Maybe you should try to update de version of the firmware. Take a look here: https://www.arduino.cc/en/Tutorial/WiFiNINAFirmwareUpdater
Ok, I followed the directions there, and it seems that I messed up the Arduino previously, so I ordered a replacement. We'll see if that one works.
Thanks, Brazillino!
system
Closed
4
