Hi, everyone. I just started learning Arduino and am having driver troubles from the start. I'm using a Windows 10 64-bit machine and have installed the Arduino IDE 1.8.8
The Arduino I'm using is from the Vilros Ultimate Starter Kit that I purchased about two years ago and finally have time to play around with. I'm hoping the UNO is genuine and not a Chinese knockoff. I've included photos of the board for reference.
My computer is not recognizing the Arduino.inf driver. When I plug the board in to my USB and I go to Control Panel->Devices, under Other Devices the UNO is shown as Unknown USB Device (Device Descriptor Request Failed). When I try to update the driver and point to the Arduino.inf file, I get an error "The folder you specified doesn't contain a compatible software driver for your device. If the folder contains a driver, make sure it is designed to work with Windows for x64 based-systems."
If it wait long enough, the Arduino sometimes comes to life and is recognized. Like the machine finally found the driver. But if I disconnect the UNO and plug it back in, the problem starts all over again. When the board was communicating, Windows appeared to use a generic driver. (see driver photo).
I was able to capture the Board Info the time it worked:
BN: Arduino/Genuino Uno
VID: 2A03
PID: 0043
SN: 854393131303517102D0
What could be the problem? I'm assuming it's a software issue, because the problem is centered around the driver. But would a bad board or a knockoff board cause this issue? I'm happy to buy a replacement board, but since it came to life a few times, I'm assuming that's not the problem.
Help!
