Thanks guys for the awesome UNO. Most educational. I don't know much about hardware and tried to use a 12v 1amp 240v power pack. It registered 16v open circuit, but came down to about 14v when just powering the Uno. All good so far.
I then with my lack of knowledge tried to breadboard a external load onto the Uno power plug. ie. sharing power... there was a little spark as I touched the external load onto the Uno power plug (direct onto the plug) and the Uno stopped responding to IDE, ie. leds still on but cannot down load code.
I did an awful lot of research and found
which seemed to possibly be the problem. Anyway, spent lots of time and had problems with the Flip USB driver on Windows 7 and eventually blew the board by touching the wrong things together
(you know, the little 'crackle, pop, smoke thingy')
My basic question is,
'It seems playing around with the power supply to the Uno, while the Uno was ON, reset something in the board so it no longer communicated'
Is there some way to 'short out' any noise, sparks, etc so they don't travel into the Uno via the power supply jack? If so, can you give me a circuit diagram so I can try and implement it with an external project load connected to the Uno power jack?
I only have limited electronics knowledge, but, for example, would you put a small capacitor across the power supply jack to dampen any spurious noise going into the power jack?
Another 'fix' I've heard of is putting a 'kick back diode' across the power supply?
Any thoughts most appreciated.
Cheers,
ps. Thinking further about what I did, if the external load was too big for the 12v 1amp supply it would have pulled down the voltage on the Uno power plug at least when starting up, and may have caused damage that way?
