Uno Q not detected by Applab, CLI is working
My Arduino Q 4Gb stopped working in SBC mode and I can't connect to it with Applab (over USB). I tried my 2Gb Uno Q and it works (not a problem with cables).
I've tried to use Arduino CLI to download new firmware and it reports that all software packages are updated.
The LED matrix works, I get the Arduino symbol and the pumping heart.
I don't have any more clues how to get it to work again.
The heart animation is supposed to show that the board is booted but it sounds like you don't have USB output. It is possible to access the Linux console via the JCTL header and observe the boot-up messages as well as log into Linux which might provide a clue and allow access to the Linux system although online results seems to suggest that the USB port can't be fixed this way :-( . Signals on the JCTL header have 1.8V logic, so will require a UART adapter capable of working at this voltage level. Arduino sell their own BugHopper adapter. There is also one sold by DSD Tech on Amazon.
This is at least the third post to this effect that I have seen in the last two weeks. It seems that the USB interface is being left in an unexpected state after the firmware update. I would suggest contacting Arduino Support via their online contact form.
This is what I could see by using putty and bughopper
If you are using IBMPC + Windows, connect the UNO Q board to the PC with a USB-C/USB-A cable. The board must be detected and assigned a COM Port. If not, the board is in trouble.
That is interesting as evidently Linux is booted up and you have been able to log in and set a password. It probably needs someone from the Arduino Team to comment regarding the next steps.
It might be worth noting whether running:
sudo dmesg
reveals any errors?
I might also be tempted to try:
sudo nmcli dev wifi list
to see whether it lists the wifi (wlan) interface. If it does, try setting up WiFi manually using:
sudo nmcli dev wifi connect <WiFi-SSID> password <WiFi-password>
and see whether it connects to your WiFi network. If it does, then it might be possible to update the OS and run arduino-cli to update AppLab. It might also be possible to connect using AppLab on the computer over the WiFi network.
Of course, that does not deal with the USB problem which probably requires the expertise of someone like @ptillisch from the Arduino Team.
