UNO R3 intermittent boot
I'm new to this Arduino Forum and hope to find a solution to my problem. First, here is my issue. I'm using an Arduino UNO R3 as a countdown timer and pet treat dispenser manager. The devices connected to the Arduino are, IR sensor, Servo motor, LCD, 7-Segment LED, RTC and a relay. Basically the project works as such...a push button starts a 15 minute count-down routine. After 15 minutes elapses the Arduino sends a pulse to the relay that triggers a door latch solenoid. Every (3) minutes a second timer tells the servo to rotate to dispense a treat. All of this works fine. The issue I am having is that intermittently the Arduino seems to not boot up. Sometimes I need to power cycle the Arduino several times to get it to work. I am using a buck converter to power the Arduino via the +5volt pin. All other devices are powered with a separate power supply. I have tried powering with the barrel jack and also the USB but get the same issue. Is this a known issue with Arduino? I don't believe this is a bad boot routine as the board will boot after several power supply cycles. Any thoughts?
Welcome to the forum
Please post your sketch, using code tags when you do, and a schematic of your project showing all components, how they are connected and powered
No.
Why two displays? The LCD can do everything the 7seg can, and more.
That should have been in your list of devices.
You do not need an RTC for a fifteen-minutes and three-minutes timer.
Intermittent is human-caused. Wiggling the wires sometimes makes contact. Show your soldering.
The animal wishes that it would not be the victim because you can't make your toy work.
Arduinos are designed for experimentation and learning, often used with breadboards and loose wires, which can become unreliable if vibrated. They are not built for harsh, dirty, or electrically noisy environments commonly found in industrial, automotive, or other commercial applications, making them unsuitable for such settings.
To ensure we can provide the most accurate assistance, please include detailed information about your setup. Specify the exact board, shield, wiring configuration, and power sources you are using. An annotated schematic is ideal, as it provides a clear overview of your setup, but be sure to also include links to the technical specifications of your hardware components.
Before posting your code, please review the forum guidelines and use code tags for better readability. Also, provide links to the technical information about your hardware, and include a preliminary schematic that shows all power, ground, and connections. For additional guidance, you can refer to this link: Useful Links and Tutorials. Note that in this context, breadboard diagrams are not considered proper schematics.
Very bad idea as the 5V pin is an output not an input
Do you power them down as well?
