Copyright 2020-2025, Ludwig V. <https://github.com/ludwig-v>
Date: 2025-06-07
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License at <http://www.gnu.org/licenses/> for
more details.
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
// Libraries //
#include <EEPROM.h>
#include <SPI.h>
#include <mcp2515.h> // https://github.com/autowp/arduino-mcp2515 + https://github.com/watterott/Arduino-Libs/tree/master/digitalWriteFast
#include <Thread.h> // https://github.com/ivanseidel/ArduinoThread slightly modified to unprotect runned() function
#include <ThreadController.h>
// Configuration //
#define SKETCH_VERSION "2.0"
#define CAN_RCV_BUFFER 40
#define CAN_DEFAULT_DELAY 5 // Delay between multiframes (ms)
#define MAX_DATA_LENGTH 512
#define CS_PIN_CAN0 9
#define SERIAL_SPEED 115200
#define CAN_SPEED CAN_500KBPS // Diagnostic CAN bus - High Speed
#define CAN_FREQ MCP_8MHZ // Switch to 8MHZ if you have a 8Mhz module
#define GETSEED_MAX_ATTEMPTS 8
// Initialization //
MCP2515 CAN0(CS_PIN_CAN0); // CAN-BUS Shield
// Variables //
// My variables
bool Dump = false; // Passive dump mode, dump Diagbox frames
char tmp[4];
int CAN_EMIT_ID = 0x752; // BSI
int CAN_RECV_ID = 0x652; // BSI
int additionalFrameID;
byte DiagSess = 0x03;
char receiveDiagFrameData[MAX_DATA_LENGTH];
int receiveDiagFrameRead = 0;
int receiveDiagFrameSize = 0;
byte receiveDiagDataPos = 0;
bool multiframeOverflow = false;
int receiveDiagFrameAlreadyFlushed = 0;
byte LIN = 0;
bool waitingReplySerialCMD = false;
unsigned long lastCMDSent = 0;
bool waitingUnlock = false;
byte getSeedAttempts = 0;
unsigned short UnlockKey = 0x0000;
byte UnlockService = 0x00;
char UnlockCMD[5];
char SketchVersion[4];
byte framesDelayInput = CAN_DEFAULT_DELAY;
byte framesDelay = CAN_DEFAULT_DELAY;
bool customFrameSize = false;
int sendingAdditionalDiagFramesPos = 0;
bool sendingAdditionalDiagFrames = false;
unsigned long lastSendingAdditionalDiagFrames = 0;
bool readingCAN = false;
bool parsingCAN = false;
bool Lock = false;
unsigned long lastKeepAliveReceived = 0;
bool sendKeepAlives = false;
byte sendKeepAliveType = 'U';
unsigned long lastRoutineAnswerReceived = 0;
bool sendRoutineChecks = false;
byte sendRoutineCheckType = 'U';
byte routineID[2];
struct can_frame canMsgRcvBuffer[CAN_RCV_BUFFER];
ThreadController controllerThread = ThreadController();
Thread readCANThread = Thread();
Thread everySecondThread = Thread();
Thread parseCANThread = Thread();
Thread sendAdditionalDiagFramesThread = Thread();
Serial.begin(SERIAL_SPEED);
CAN0.reset();
CAN0.setBitrate(CAN_SPEED, CAN_FREQ);
while (CAN0.setNormalMode() != MCP2515::ERROR_OK) {
delay(100);
strcpy(SketchVersion, SKETCH_VERSION);
for (int i = 0; i < CAN_RCV_BUFFER; i++) {
canMsgRcvBuffer[i].can_id = 0;
canMsgRcvBuffer[i].can_dlc = 0;
readCANThread.onRun(readCAN);
readCANThread.setInterval(0);
everySecondThread.onRun(everySecond);
everySecondThread.setInterval(1000);
parseCANThread.onRun(parseCAN);
parseCANThread.setInterval(4);
sendAdditionalDiagFramesThread.onRun(sendAdditionalDiagFrames);
sendAdditionalDiagFramesThread.setInterval(1);
controllerThread.add( & readCANThread);
controllerThread.add( & everySecondThread);
controllerThread.add( & parseCANThread);
controllerThread.add( & sendAdditionalDiagFramesThread);
/* https://github.com/ludwig-v/psa-seedkey-algorithm */
long transform(byte data_msb, byte data_lsb, byte sec[]) {
long data = (data_msb << 8) | data_lsb;
long result = ((data % sec[0]) * sec[2]) - ((data / sec[0]) * sec[1]);
if (result < 0)
result += (sec[0] * sec[2]) + sec[1];
return result;
unsigned long compute_response(unsigned short pin, unsigned long chg) {
byte sec_1[3] = {0xB2, 0x3F, 0xAA};
byte sec_2[3] = {0xB1, 0x02, 0xAB};
long res_msb = transform((pin >> 8), (pin & 0xFF), sec_1) | transform(((chg >> 24) & 0xFF), (chg & 0xFF), sec_2);
long res_lsb = transform(((chg >> 16) & 0xFF), ((chg >> 8) & 0xFF), sec_1) | transform((res_msb >> 8), (res_msb & 0xFF), sec_2);
return (res_msb << 16) | res_lsb;
int int_pow(int base, int exp) {
int result = 1;
while (exp) {
if (exp % 2)
result *= base;
exp /= 2;
base *= base;
return result;
int ahex2int(char a, char b) {
a = (a <= '9') ? a - '0' : (a & 0x7) + 9;
b = (b <= '9') ? b - '0' : (b & 0x7) + 9;
return (a << 4) + b;
void receiveDiagMultiFrame(can_frame frame) {
int i = 0;
for (i = 2; i < frame.can_dlc; i++) {
snprintf(tmp, 3, "%02X", frame.data[i]);
receiveDiagFrameData[receiveDiagFrameRead] = tmp[0];
receiveDiagFrameData[receiveDiagFrameRead + 1] = tmp[1];
receiveDiagFrameRead += 2;
void receiveAdditionalDiagFrame(can_frame frame, bool encap) {
int i = 0;
int frameOrder = 0;
int framePos = 0;
byte maxBytesperFrame = 8;
if (encap) // LIN
maxBytesperFrame--;
if (frame.data[0] == 0x20) {
if (receiveDiagDataPos == 0) {
receiveDiagDataPos += 15; // 21 > 2F
receiveDiagDataPos += 16; // 20 > 2F
if (receiveDiagFrameAlreadyFlushed > 0) {
frameOrder = frame.data[0] - 0x20;
frameOrder = frame.data[0] - 0x21 + receiveDiagDataPos;
for (i = 1; i < frame.can_dlc; i++) {
framePos = (frameOrder * (maxBytesperFrame - 1) * 2) + ((i - 1) * 2) + 1;
// 6 bytes already received + 7 bytes max per frame
framePos = ((maxBytesperFrame - 2) * 2) + (frameOrder * (maxBytesperFrame - 1) * 2) + ((i - 1) * 2) + 1;
if (framePos > MAX_DATA_LENGTH) { // Avoid overflow
multiframeOverflow = true;
if (Dump) {
i = (framePos - 1) / 2;
Serial.print("Warning: Truncated data ");
Serial.print(i);
Serial.print("/");
Serial.println(receiveDiagFrameSize);
receiveDiagFrameData[framePos - 1] = tmp[0];
receiveDiagFrameData[framePos] = tmp[1];
if (framesDelay > 0) { // Can't flush buffer fast enough if no delay (some frames will be lost, data will be truncated)
if (frame.data[0] == 0x2F) {
if (Dump && receiveDiagFrameAlreadyFlushed == 0) {
snprintf(tmp, 4, "%02X", frame.can_id);
Serial.print(tmp);
Serial.print(":");
receiveDiagFrameAlreadyFlushed += receiveDiagFrameRead;
receiveDiagFrameData[framePos + 1] = '\0';
receiveDiagDataPos = receiveDiagFrameRead = 0;
Serial.print(receiveDiagFrameData);
if ((receiveDiagFrameRead + receiveDiagFrameAlreadyFlushed) == (receiveDiagFrameSize * 2) || framePos > MAX_DATA_LENGTH) { // Data complete or overflow
Serial.print(tmp);
Serial.print(":");
receiveDiagFrameData[receiveDiagFrameRead] = '\0';
receiveDiagDataPos = receiveDiagFrameRead = receiveDiagFrameAlreadyFlushed = receiveDiagFrameSize = 0;
Serial.println(receiveDiagFrameData);
framesDelay = CAN_DEFAULT_DELAY; // Restore default delay
void sendAdditionalDiagFrames() {
if (!Lock && sendingAdditionalDiagFrames && millis() - lastSendingAdditionalDiagFrames >= framesDelay) {
lastSendingAdditionalDiagFrames = millis();
int i = 0;
int frameLen = 0;
byte tmpFrame[8] = {0, 0, 0, 0, 0, 0, 0, 0};
struct can_frame diagFrame;
for (i = sendingAdditionalDiagFramesPos; i < receiveDiagFrameRead; i += 2) {
sendingAdditionalDiagFramesPos = i;
tmpFrame[frameLen] = ahex2int(receiveDiagFrameData[i], receiveDiagFrameData[(i + 1)]);
frameLen++;
if (LIN > 0) {
if (frameLen > 0 && (frameLen % 7) == 0) { // Multi-frames
diagFrame.data[0] = LIN;
diagFrame.data[1] = additionalFrameID;
diagFrame.data[2] = tmpFrame[0];
diagFrame.data[3] = tmpFrame[1];
diagFrame.data[4] = tmpFrame[2];
diagFrame.data[5] = tmpFrame[3];
diagFrame.data[6] = tmpFrame[4];
diagFrame.data[7] = tmpFrame[5];
frameLen = 8;
i -= 4; // First bytes are used by diag data
additionalFrameID++;
if (additionalFrameID > 0x2F) {
additionalFrameID = 0x20;
diagFrame.can_id = CAN_EMIT_ID;
diagFrame.can_dlc = frameLen;
CAN0.sendMessage( & diagFrame);
frameLen = 0;
return;
} else if ((i + 2) == receiveDiagFrameRead) {
frameLen = frameLen + 2;
if (frameLen > 0 && (frameLen % 8) == 0) { // Multi-frames
diagFrame.data[0] = additionalFrameID;
diagFrame.data[1] = tmpFrame[0];
diagFrame.data[2] = tmpFrame[1];
diagFrame.data[3] = tmpFrame[2];
diagFrame.data[4] = tmpFrame[3];
diagFrame.data[5] = tmpFrame[4];
diagFrame.data[6] = tmpFrame[5];
diagFrame.data[7] = tmpFrame[6];
frameLen = 8;
i -= 2; // First byte is used by diag data
frameLen = 0;
return;
frameLen = frameLen + 1;
return;
void sendDiagFrame(char * data, int frameFullLen, bool Raw) {
int i = 0;
int frameLen = 0;
for (i = 0; i < frameFullLen && i < 16; i += 2) {
if (isxdigit(data[i]) && isxdigit(data[i + 1])) {
tmpFrame[frameLen] = ahex2int(data[i], data[(i + 1)]);
frameLen++;
if (data[i] == -16) {
Serial.println("000000");
Serial.println("7F0000");
return;
if (tmpFrame[0] == 0x31) {
if (tmpFrame[1] == 0x01) { // Start Routine
sendRoutineChecks = true;
sendRoutineCheckType = 'U'; // UDS
routineID[0] = tmpFrame[2];
routineID[1] = tmpFrame[3];
} else if (tmpFrame[1] != 0x03) {
sendRoutineCheckType = 'K'; // KWP
routineID[0] = tmpFrame[1];
routineID[1] = 0x01;
if (LIN > 0 && !Raw) {
if (frameLen > 6) { // Multi-frames
diagFrame.data[1] = (0x10 + ((frameFullLen / 2) / 256));
diagFrame.data[2] = ((frameFullLen / 2) % 256);
diagFrame.data[3] = tmpFrame[0];
diagFrame.data[4] = tmpFrame[1];
diagFrame.data[5] = tmpFrame[2];
diagFrame.data[6] = tmpFrame[3];
diagFrame.data[7] = tmpFrame[4];
frameLen = 8;
additionalFrameID = 0x21;
diagFrame.data[1] = frameLen;
additionalFrameID = 0x00;
if (frameLen > 7 && !Raw) { // Multi-frames
diagFrame.data[0] = (0x10 + ((frameFullLen / 2) / 256));
diagFrame.data[1] = ((frameFullLen / 2) % 256);
frameLen = 8;
if (Raw) {
diagFrame.data[0] = tmpFrame[0];
diagFrame.data[1] = tmpFrame[1];
diagFrame.data[2] = tmpFrame[2];
diagFrame.data[3] = tmpFrame[3];
diagFrame.data[4] = tmpFrame[4];
diagFrame.data[5] = tmpFrame[5];
diagFrame.data[6] = tmpFrame[6];
diagFrame.data[7] = tmpFrame[7];
diagFrame.data[0] = frameLen;
return;
void everySecond() {
if (sendKeepAlives) {
if (sendKeepAliveType == 'K') { // KWP
if (LIN > 0) {
diagFrame.data[1] = 0x01;
diagFrame.data[2] = 0x3E;
diagFrame.can_dlc = 3;
diagFrame.data[0] = 0x01;
diagFrame.data[1] = 0x3E;
diagFrame.can_dlc = 2;
} else { // UDS
if (LIN > 0) {
diagFrame.data[1] = 0x02;
diagFrame.data[3] = 0x00;
diagFrame.can_dlc = 4;
diagFrame.data[0] = 0x02;
diagFrame.data[2] = 0x00;
if (sendRoutineChecks) {
if (sendRoutineCheckType == 'K') { // KWP
diagFrame.data[0] = 0x03;
diagFrame.data[1] = 0x31;
diagFrame.data[3] = routineID[0];
diagFrame.data[4] = 0x01;
} else { // UDS
diagFrame.data[0] = 0x04;
diagFrame.data[2] = 0x03;
diagFrame.data[4] = routineID[1];
diagFrame.can_dlc = 5;
return;
int pos = 0;
void recvWithTimeout() {
unsigned long lastCharMillis = 0;
char rc;
lastCharMillis = millis();
while (Serial.available() > 0) {
rc = Serial.read();
receiveDiagFrameData[pos] = rc;
receiveDiagFrameRead = pos;
if (millis() - lastCharMillis >= 1000 || rc == '\n' || pos >= MAX_DATA_LENGTH) {
receiveDiagFrameData[pos] = '\0';
if (receiveDiagFrameData[0] == '>') { // IDs Pair changing
pos = 0;
char * ids = strtok(receiveDiagFrameData + 1, ":");
while (ids != NULL) {
if (pos == 0) {
CAN_EMIT_ID = strtoul(ids, NULL, 16);
} else if (pos == 1) {
CAN_RECV_ID = strtoul(ids, NULL, 16);
pos++;
ids = strtok(NULL, ":");
LIN = 0;
Dump = false;
Serial.println("OK");
} else if (receiveDiagFrameData[0] == 'T') { // Change CAN multiframes delay
framesDelayInput = strtoul(receiveDiagFrameData + 1, NULL, 10);
} else if (receiveDiagFrameData[0] == ':') { // Unlock with key
pos = 0;
if (pos == 0) {
UnlockKey = strtoul(ids, NULL, 16);
UnlockService = strtoul(ids, NULL, 16);
} else if (pos == 2) {
DiagSess = strtoul(ids, NULL, 16);
pos++;
snprintf(tmp, 3, "%02X", UnlockService);
strcpy(UnlockCMD, "27");
strcat(UnlockCMD, tmp);
char diagCMD[5] = "10";
snprintf(tmp, 3, "%02X", DiagSess);
strcat(diagCMD, tmp);
sendDiagFrame(diagCMD, strlen(diagCMD), false);
if (DiagSess == 0xC0) { // KWP
sendKeepAliveType = 'K';
} else { // UDS
sendKeepAlives = true;
waitingUnlock = true;
} else if (receiveDiagFrameData[0] == 'V') {
Serial.println(SketchVersion);
} else if (receiveDiagFrameData[0] == 'L') {
LIN = strtoul(receiveDiagFrameData + 1, NULL, 16);
} else if (receiveDiagFrameData[0] == 'W') {
customFrameSize = true;
receiveDiagFrameSize = strtoul(receiveDiagFrameData + 1, NULL, 10) * 2;
Serial.println("WOK");
} else if (receiveDiagFrameData[0] == 'U') {
LIN = 0;
} else if (receiveDiagFrameData[0] == 'N') {
Dump = false;
} else if (receiveDiagFrameData[0] == 'X') {
Dump = true;
} else if (receiveDiagFrameData[0] == 'K') {
if (receiveDiagFrameData[1] == 'U' || receiveDiagFrameData[1] == 'K') {
sendKeepAliveType = receiveDiagFrameData[1];
} else if (receiveDiagFrameData[0] == 'S') {
} else if (receiveDiagFrameData[0] == 'R') {
CAN0.reset();
delay(100);
} else if (receiveDiagFrameData[0] == '?') {
snprintf(tmp, 4, "%02X", CAN_EMIT_ID);
Serial.print(tmp);
Serial.print(":");
snprintf(tmp, 4, "%02X", CAN_RECV_ID);
Serial.println(tmp);
} else if (receiveDiagFrameData[0] == '#' && receiveDiagFrameRead <= (16 + 1) && (receiveDiagFrameRead - 1) % 2 == 0) { // Send RAW frames
sendDiagFrame(receiveDiagFrameData + 1, receiveDiagFrameRead - 1, true);
waitingReplySerialCMD = true;
lastCMDSent = millis();
} else if (receiveDiagFrameData[0] == '+') { // Large writing frame splitting
sendingAdditionalDiagFramesPos = 1;
sendingAdditionalDiagFrames = true;
} else if (receiveDiagFrameRead % 2 == 0) {
char tmpFrame[16];
for (int i = 0; i < receiveDiagFrameRead && i < 16; i++) {
tmpFrame[i] = receiveDiagFrameData[i];
if (customFrameSize) { // Large writing frame splitting, recommended split size for continuous data = (receiveDiagFrameRead - 5) % 7 = 0 (ex: 250)
sendDiagFrame(tmpFrame, receiveDiagFrameSize, false);
sendDiagFrame(tmpFrame, receiveDiagFrameRead, false);
pos = 0;
pos++;
return;
if (Serial.available() > 0) {
recvWithTimeout();
timerCallback();
void parseCAN() {
if (!Lock && !parsingCAN && !sendingAdditionalDiagFrames) {
parsingCAN = true;
for (int t = 0; t < CAN_RCV_BUFFER; t++) {
if (canMsgRcvBuffer[t].can_id > 0) {
int id = canMsgRcvBuffer[t].can_id;
bool encap = false;
if (canMsgRcvBuffer[t].data[0] >= 0x40 && canMsgRcvBuffer[t].data[0] <= 0x70) { // UDS or KWP with LIN ECUs, remove encapsulation
for (int i = 1; i < canMsgRcvBuffer[t].can_dlc; i++) {
canMsgRcvBuffer[t].data[i - 1] = canMsgRcvBuffer[t].data[i];
canMsgRcvBuffer[t].can_dlc--;
encap = true;
int len = canMsgRcvBuffer[t].can_dlc;
if (canMsgRcvBuffer[t].data[0] < 0x10 && canMsgRcvBuffer[t].data[1] == 0x71) { // Routine Reply
lastRoutineAnswerReceived = millis();
if (len >= 6) { // UDS
if (canMsgRcvBuffer[t].data[5] != 0x01) { // Routine not running state
} else if (len <= 4) { // KWP
if (canMsgRcvBuffer[t].data[3] != 0x01) { // Routine not running state
if (canMsgRcvBuffer[t].data[0] < 0x10 && canMsgRcvBuffer[t].data[1] == 0x7E) {
lastKeepAliveReceived = millis();
} else if (canMsgRcvBuffer[t].data[0] < 0x10 && canMsgRcvBuffer[t].data[1] == 0x3E) {
sendKeepAlives = false; // Diagbox or external tool sending keep-alives, stop sending ours
} else if (Dump) {
if (waitingReplySerialCMD && len == 3 && canMsgRcvBuffer[t].data[0] == 0x30 && canMsgRcvBuffer[t].data[1] == 0x00) { // Acknowledgement Write
framesDelay = canMsgRcvBuffer[t].data[2];
if (LIN > 0)
sendingAdditionalDiagFramesPos = 10; // 5 bytes already sent
sendingAdditionalDiagFramesPos = 12; // 6 bytes already sent
lastCMDSent = 0;
} else if (len > 2 && canMsgRcvBuffer[t].data[0] >= 0x10 && canMsgRcvBuffer[t].data[0] <= 0x19) { // Acknowledgement Read
receiveDiagFrameSize = ((canMsgRcvBuffer[t].data[0] - 0x10) * 256) + canMsgRcvBuffer[t].data[1];
if (waitingReplySerialCMD && LIN) {
diagFrame.data[1] = 0x30;
diagFrame.data[3] = framesDelayInput;
lastCMDSent = 0;
} else if (waitingReplySerialCMD) {
diagFrame.data[0] = 0x30;
diagFrame.data[1] = 0x00;
diagFrame.data[2] = framesDelayInput;
lastCMDSent = 0;
receiveDiagMultiFrame(canMsgRcvBuffer[t]);
} else if (len > 1 && canMsgRcvBuffer[t].data[0] >= 0x20 && canMsgRcvBuffer[t].data[0] <= 0x2F) {
if (!multiframeOverflow)
receiveAdditionalDiagFrame(canMsgRcvBuffer[t], encap);
} else if (len == 3 && canMsgRcvBuffer[t].data[0] == 0x30 && canMsgRcvBuffer[t].data[1] == 0x00) {
// Ignore in dump mode
} else if (id != 0x353) { // Ignore 0x353 blank frame from some BSI
snprintf(tmp, 4, "%02X", id);
Serial.print(tmp);
Serial.print(":");
for (int i = 1; i < len; i++) { // Strip first byte = Data length
snprintf(tmp, 3, "%02X", canMsgRcvBuffer[t].data[i]);
Serial.print(tmp);
if (id == CAN_RECV_ID) {
if (LIN > 0)
lastCMDSent = 0;
lastCMDSent = 0;
lastCMDSent = 0;
Serial.print(tmp);
if (canMsgRcvBuffer[t].data[0] < 0x10 && (canMsgRcvBuffer[t].data[1] == 0x7F || (lastCMDSent > 0 && millis() - lastCMDSent >= 1000))) { // Error / No answer
if (canMsgRcvBuffer[t].data[2] == 0x3E) {
sendKeepAlives = false; // Stop sending Keep-Alives
if (canMsgRcvBuffer[t].data[2] == 0x31) {
sendRoutineChecks = false; // Stop sending Routine Checks
if (waitingUnlock && canMsgRcvBuffer[t].data[1] == 0x7F && canMsgRcvBuffer[t].data[2] == 0x27 && canMsgRcvBuffer[t].data[3] != 0x37) {
if (waitingUnlock && getSeedAttempts <= GETSEED_MAX_ATTEMPTS) {
if (lastCMDSent > 0 && millis() - lastCMDSent >= 2000) {
sendDiagFrame(UnlockCMD, strlen(UnlockCMD), false);
getSeedAttempts++;
lastCMDSent = 0;
} else if (waitingUnlock && canMsgRcvBuffer[t].data[0] < 0x10 && canMsgRcvBuffer[t].data[1] == 0x50 && canMsgRcvBuffer[t].data[2] == DiagSess) {
if (lastRoutineAnswerReceived > 0 && millis() - lastRoutineAnswerReceived >= 4000) { // ECU connection lost, no answer
} else if (sendKeepAlives) {
if (lastKeepAliveReceived > 0 && millis() - lastKeepAliveReceived >= 4000) { // ECU connection lost, no answer
Serial.println("7F3E03"); // Custom error
if (waitingUnlock && canMsgRcvBuffer[t].data[0] < 0x10 && canMsgRcvBuffer[t].data[1] == 0x67 && canMsgRcvBuffer[t].data[2] == UnlockService) {
char SeedKey[9];
char UnlockCMD_Seed[16];
snprintf(tmp, 3, "%02X", canMsgRcvBuffer[t].data[3]);
strcpy(SeedKey, tmp);
snprintf(tmp, 3, "%02X", canMsgRcvBuffer[t].data[4]);
strcat(SeedKey, tmp);
snprintf(tmp, 3, "%02X", canMsgRcvBuffer[t].data[5]);
snprintf(tmp, 3, "%02X", canMsgRcvBuffer[t].data[6]);
unsigned long Key = compute_response(UnlockKey, strtoul(SeedKey, NULL, 16));
snprintf(SeedKey, 9, "%08lX", Key);
strcpy(UnlockCMD_Seed, "27");
snprintf(tmp, 3, "%02X", (UnlockService + 1)); // Answer
strcat(UnlockCMD_Seed, tmp);
strcat(UnlockCMD_Seed, SeedKey);
if (Dump) {
Serial.print(tmp);
Serial.print(":");
Serial.println(UnlockCMD_Seed);
sendDiagFrame(UnlockCMD_Seed, strlen(UnlockCMD_Seed), false);
canMsgRcvBuffer[t].can_id = 0;
parsingCAN = false;
void timerCallback() {
controllerThread.run();
void readCAN() {
if (!Lock && !readingCAN) {
struct can_frame canMsgRcv;
readingCAN = true;
while (CAN0.readMessage( & canMsgRcv) == MCP2515::ERROR_OK) {
if (canMsgRcvBuffer[i].can_id == 0) { // Free in buffer
canMsgRcvBuffer[i] = canMsgRcv;
parseCANThread.runned(); // Delay thread execution to avoid loosing messages
readingCAN = false;
