Continuing the discussion from UNO R4 Wifi is not recognized or wrong recognized:
bymistake i did yes for all questions, what should i do? Please help sir
Don't worry about it. That won't cause any problems.
Since I don't know what procedure you have been following, I think it will be best to start fresh. I'll provide a complete set of instructions you can follow to update the firmware on the "bridge" module of your UNO R4 WiFi board:
Arduino - CC BY-SA 4.0 (cropped)
unor4wifi-update-windows folder that was created when you extracted the downloaded unor4wifi-update-windows.zip file at the previous step in the instructions.unor4wifi-update-windows folder, hold the Shift key while clicking the right hand button on the mouse.bin\espflash write-bin -b 115200 0x0 (Get-Item .\firmware\UNOR4-WIFI-S3-*.bin).FullName
Start flashing firmware
[2023-07-11T06:39:09Z INFO ] Detected 2 serial ports
[2023-07-11T06:39:09Z INFO ] Ports which match a known common dev board are highlighted
[2023-07-11T06:39:09Z INFO ] Please select a port
⯠COM1
COM42- USB Serial Device (COM42)
If so, use the ā key on your keyboard to select the port of the UNO R4 WiFi board from the list, and then press the Enter key.? Remember this serial port for future use? (y/n) āŗ
Press the N key on your keyboard.Chip type: esp32s3 (revision v0.1)
Crystal frequency: 40MHz
Flash size: 8MB
Features: WiFi, BLE
MAC address: dc:54:75:c4:c6:54
[00:00:15] [========================================] 826/826 0x0
The board should now be recognized correctly in Arduino IDE once again.
Please let me know if you have any questions or problems while following those instructions.
Thank you very much sir, this means a lot, really! thank you you are great sir, I also have a doubt sir how should i updated firmware for my arduino uno r4 wifi so that no other problem would pop up again. once again thank you.
You are welcome. I'm glad if I was able to be of assistance.
Regards,
Per
even with the jumper mine still says "Ć No such file or directory (os error 2)" and shows up as ESP32 family device in the ide I rally need help with this one.
@ptillisch please answer this i am having a very similar problem!
Hi @timmytheterror. Please add a forum reply here to tell us which operating system you are using (e.g., "Windows")?
I ask because I would like to give you the appropriate instructions for your operating system.
Mac OS 10.15.7 catalina
OK, great. Please follow these instructions:
unor4wifi-update-macos folder.sudo xattr -d com.apple.quarantine bin/espflash; bin/espflash write-bin -b 115200 0x0 ./firmware/UNOR4-WIFI-S3-*.bin
[2024-04-04T04:54:21Z INFO ] š A new version of espflash is available: v3.0.0
[2024-04-04T04:54:21Z INFO ] Detected 6 serial ports
[2024-04-04T04:54:21Z INFO ] Ports which match a known common dev board are highlighted
[2024-04-04T04:54:21Z INFO ] Please select a port
⯠/dev/cu.wlan-debug
/dev/tty.wlan-debug
/dev/cu.Bluetooth-Incoming-Port
/dev/tty.Bluetooth-Incoming-Port
/dev/cu.usbmodem2114101 - USB JTAG_serial debug unit
/dev/tty.usbmodem2114101 - USB JTAG_serial debug unit
If so, use the ā key on your keyboard to select the first "USB JTAG_serial debug unit" port from the list (/dev/cu.usbmodem2114101 in the example above), and then press the Enter key.? Remember this serial port for future use? (y/n) āŗ
Press the N key on your keyboard.[2024-04-04T04:50:38Z INFO ] Serial port: '/dev/cu.usbmodem2114101'
[2024-04-04T04:50:38Z INFO ] Connecting...
[2024-04-04T04:50:38Z INFO ] Using flash stub
Flash size: 8MB
Features: WiFi, BLE
[00:00:16] [========================================] 877/877 0x0
