- I am working on a tutorial for logic analyzer usage.
- This tutorial will be based on a previous post:
Making Arduino State Machines Visible on a Logic Analyzer - The schematic below shows the interface used to connect an Arduino UNO to a 16-channel logic analyzer or oscilloscope.
The circuit converts internal Arduino firmware states and events into observable digital signals, allowing a logic analyzer to monitor program execution. This provides non-intrusive, timing-accurate debugging of embedded code.
I use SPI to send 3 bytes (about 4us) i.e. debugging values, to the 24 bit register output.
A 4-channel oscilloscope can also be used with this circuit.
- The two 74HC595 shift registers generate the signals sent to the logic analyzer.
- The TPIC6B595 is used to drive diagnostic LEDs.
Hardware changes or improvement are welcomed.
- The transitionPin can be any pin, 2-9 or A0-A3.
