Upload a sketch on a MacBook?
I'm using a 2020-MacBook-Air, and it only has 2 USB-C ports. However when I connected it with a USB-B-to-USB-C adapter, it didn't quite work. Do you have any suggestions?
Please provide a detailed description of what you mean by "it didn't quite work". Post the full and exact text of any error or warning messages you might be getting.
pert:
All I know is that it didn't say that the board is connected so I couldn't upload (even with the plugin).
Are you using the Arduino IDE or the Arduino Web Editor?
pert:
I am using Web Editor. But the IDE doesn't work either.
You may have to find a driver, esp. if your are using a clone knockoff counterfeit board.
What exact board do you have and what MacOS version are you running?
a7
You may have a "charging cord". I've run across them from time to time. No data lines, just power.
-jim lee
alto777:
a7
I use Arduino UNO ATMEGA-328P and MacOS Big-Sur.
Bzzzzt!
https://forum.arduino.cc/index.php?topic=714226.0
Looks like Big Sur broke some things. Good luck, but you have company in this misery.
You should first of course make sure about the cable as @JimLee points out. Been distracted by that one a few times myself. Charging cables shou,d be illegal or marked as such, just sayin’.
HTH
a7
