Continuing the discussion from Programmer is not responding:
I have the same issue with same error codes but mine blinks after I let go of the reset button how do i fix it?
Hi @manu_rs. I'm going to ask you to provide the full verbose output from an upload attempt.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
☑ compile in the "Preferences" dialog.<CODE/> icon on the post composer toolbar.```) to your reply to make sure the error messages are correctly formatted.avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\**********\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM1
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x8b
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x8b
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x8b
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x8b
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x8b
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x8b
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x8b
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x8b
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x8b
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x8b
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
This error might be caused by having the wrong port selected from the Tools > Port menu in Arduino IDE.
Please perform this experiment to verify that the port you have selected is your Arduino board:
With official boards, the port will be labeled with the board name in the menu (e.g., "COM42 (Arduino Uno)"). In this case, you can be fairly confident that you have identified the port. Select that port from the menu and try uploading again.
With some cheap derivative boards the port will not be labeled. You can positively identify the port using this procedure:
If the upload still fails, or if no new port appeared after you plugged the Arduino board into your computer, add a reply here to let us know and we'll investigate the problem further.
