I am working in my project using arduino uno r3, with the use of SIM7600 CE to receive signal strength, i have a problem.
I have a usb ttl converter called cp2102 and when i just connect it with the SIM 760CE and connect to my computer. I use a program called SScom3.2 to send AT commmands which is sucussful and i recevied what i want.
However, i my project, i am required to send AT commands through arduino and i try for a week and i am still struggling on it. When i do the following set up and type in AT commands in the serial monitor, I do not have any response. What is the problem? Thank you.
I connect the following pins of arduino uno r3 and SIM 7600CE.
SIM 7600 CE . Arduino
TXD 2 (RX arduino)
RXD 3(TX arduino)
VDD 5V
Supply 5V
GND GND
My program is at the below.
Software serial multple serial test
Receives from the hardware serial, sends to software serial.
Receives from software serial, sends to hardware serial.
The circuit:
- RX is digital pin 10 (connect to TX of other device)
- TX is digital pin 11 (connect to RX of other device)
Note:
Not all pins on the Mega and Mega 2560 support change interrupts,
so only the following can be used for RX:
10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
Not all pins on the Leonardo and Micro support change interrupts,
8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
created back in the mists of time
modified 25 May 2012
by Tom Igoe
based on Mikal Hart's example
This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Goodnight moon!");
// set the data rate for the SoftwareSerial port
mySerial.begin(115200);
mySerial.println("Hello, world?");
void loop() { // run over and over
if (mySerial.available()) {
Serial.write(mySerial.read());
if (Serial.available()) {
mySerial.write(Serial.read());
