USB host shield
Can i know how many versions are there for the host shield library?
I need to get the oldest version in order to work with my arduino 0023 8)
Thanks in advance.
C:\Users\116896\Documents\Arduino\libraries\USB_Host_Shield\Max3421e.cpp: In static member function 'static void MAX3421E::setRST(uint8_t)':
C:\Users\116896\Documents\Arduino\libraries\USB_Host_Shield\Max3421e.cpp:58: error: 'PORTJ' was not declared in this scope
C:\Users\116896\Documents\Arduino\libraries\USB_Host_Shield\Max3421e.cpp:58: error: 'PJ2' was not declared in this scope
C:\Users\116896\Documents\Arduino\libraries\USB_Host_Shield\Max3421e.cpp:60: error: 'PORTJ' was not declared in this scope
C:\Users\116896\Documents\Arduino\libraries\USB_Host_Shield\Max3421e.cpp:60: error: 'PJ2' was not declared in this scope
C:\Users\116896\Documents\Arduino\libraries\USB_Host_Shield\Max3421e.cpp: In static member function 'static uint8_t MAX3421E::readINT()':
C:\Users\116896\Documents\Arduino\libraries\USB_Host_Shield\Max3421e.cpp:65: error: 'PINE' was not declared in this scope
C:\Users\116896\Documents\Arduino\libraries\USB_Host_Shield\Max3421e.cpp:65: error: 'PE6' was not declared in this scope
C:\Users\116896\Documents\Arduino\libraries\USB_Host_Shield\Max3421e.cpp: In static member function 'static void MAX3421E::pinInit()':
C:\Users\116896\Documents\Arduino\libraries\USB_Host_Shield\Max3421e.cpp:77: error: 'DDRE' was not declared in this scope
C:\Users\116896\Documents\Arduino\libraries\USB_Host_Shield\Max3421e.cpp:77: error: 'PE6' was not declared in this scope
C:\Users\116896\Documents\Arduino\libraries\USB_Host_Shield\Max3421e.cpp:78: error: 'DDRJ' was not declared in this scope
C:\Users\116896\Documents\Arduino\libraries\USB_Host_Shield\Max3421e.cpp:78: error: 'PJ2' was not declared in this scope
this are the errors i had.
Why? That version is practically ancient.
Which version of the library are you using?
