USB
Hello !
I am new on arduino. I am trying to convert the signal from an absolute rotary encoder (ems22a) to a Pixhawk (protocol -I2C). I upload the code attach to this topic on an arduino nano.
This code is working when my USB is plugged to my computer. However, when I boot my pixhawk without the USB link on my arduino, I don't receive the data. The led TX is not solid green. There is only the led power which is laight.
I try also to plug my usb after I boot my pixhawk and it works. The led TX is green. I can remove the link afterward and it works.
It seems like I have to boot the transmission TX with my USB (once the led TX is green it works but I can only light it with the USB link) which is really weird.
Do you know how I can solve the problem ? Is there a problem in my connection or in my program ?
Thank
ems22.ino (2.74 KB)
I don't see anything wrong in your code. I never used this rotary encoder, but maybe it's an electrical problem, due to supply power.
You say
can you be more specific : what kind of supply then?
If you are French speaker, you can also ask for help in the French section of the forum.
A schematic would be helpful
I don't know anything about your rotary encoder but if there is a Forum member who does it is very unlikely that your Title will suggest to him (or her) that s/he could help you.
I suggest you edit your Original Post and write a Title that summarizes your problem. Perhaps "Problem reading EMS22A encoder when USB is disconnected"
...R
@Fabien102, please do not cross-post. Other thread removed.
