Hi there. I've got a Mkr Wifi 1010, with a built-in ESP WiFi chip.
I think I can tell that my problem is that my device is not selecting the strongest WiFi channel available. I have two access points in my house, one on channel 6 and the second on channel 1. Channel 6 is in the same room as my Arduino, channel 1 is upstairs through a bunch of walls.
From the Arduino via Serial Monitor:
18:09:46.424 -> ** Scan Networks **
18:09:51.028 -> number of available networks:2
18:09:51.028 -> 0) triangle Signal: -51 dBm Channel: 6 Encryption: WPA2
18:09:51.028 -> 1) triangle Signal: -53 dBm Channel: 1 Encryption: WPA2
When I unplug the upstairs AP (channel 1) the Arduino has no trouble connecting to the channel 6 AP. But with them both plugged in, I intermittently get failures to connect:
WiFi not connected. Reason code==2
I suspect that if I could just get the WiFiNina library to choose the stronger signal, it would work sufficiently reliably. Is there a way to make this happen?
Also, is the Reason code a signal of any sort?
Here's my code:
#include <SPI.h>
#include <WiFiNINA.h>
#include "wifi_creds.h"
Serial.println("---- Board startup ----");
WiFi.noLowPowerMode();
if (WiFi.status() != WL_CONNECTED) {
WiFi.begin(ssid, password);
Serial.print("WiFi not connected. Reason code==");
Serial.print(WiFi.reasonCode());
listNetworks2();
Serial.print("WiFi connected, RSSI == ");
Serial.print(WiFi.RSSI());
void listNetworks2() {
// scan for nearby networks:
Serial.println("** Scan Networks **");
int numSsid = WiFi.scanNetworks();
if (numSsid == -1) {
Serial.println("Couldn't get a wifi connection.");
while (true);
// print the list of networks seen:
Serial.print("number of available networks:");
Serial.println(numSsid);
// print the network number and name for each network found:
for (int thisNet = 0; thisNet < numSsid; thisNet++) {
Serial.print(thisNet);
Serial.print(") ");
Serial.print(WiFi.SSID(thisNet));
Serial.print("\tSignal: ");
Serial.print(WiFi.RSSI(thisNet));
Serial.print(" dBm");
Serial.print("\tChannel: ");
Serial.print(WiFi.channel(thisNet));
Serial.print("\tEncryption: ");
printEncryptionType2(WiFi.encryptionType(thisNet));
void printEncryptionType2(int thisType) {
// read the encryption type and print out the name:
switch (thisType) {
case ENC_TYPE_WEP:
Serial.println("WEP");
case ENC_TYPE_TKIP:
Serial.println("WPA");
case ENC_TYPE_CCMP:
Serial.println("WPA2");
case ENC_TYPE_NONE:
Serial.println("None");
case ENC_TYPE_AUTO:
Serial.println("Auto");
